Question about Casio Scientific Calculator Fx-570 Fx570 Fx570ms Wrty
How to find GCD - Casio Scientific Calculator Fx-570 Fx570 Fx570ms Wrty
How do I change a percentage to a fraction
Use this http://www.calculatorsoup.com/calculators/math/percent-to-fraction-calculator.php
OR to work it out yourself.....#
How to convert percent to fraction
  1. Divide the percent by 100 to get decimal number.
  2. Count the number of digits (d) to the right of the decimal point of the decimal number.Example: 2.56 has 2 digits to the right of the decimal point, so d=2.
  3. Calculate the factor (f) for making the decimal number an integer: f = 10 to power d
    Example:
    f = 10 power 2 = 100
  4. Multiply and divide the decimal number x by the factor f: x * f / f = y / f
    Example:
    2.56 * 100 / 100 = 256 / 100
  5. Find the greatest common divisor (gcd) of the fraction. Example:
    gcd(256,100) = 4
  6. Reduce the fraction by dividing the numerator and denominator by the gcd value: Example:
    256 / 100 = (256/4) / (100/4) = 64/25
Example One percent is equal to one hundredth:
1% = 1/100
So in order to convert percent to fraction, divide the percent by 100% and reduce the fraction.
For example 56% is equal to 56/100 with gcd=4 is equal to 14/25:
56% = 56/100 = 14/25
Sep 07, 2014 | Office Equipment & Supplies
Where is the GCF/GCD button on my TI-85 Plus Silver Edition
There are no such buttons, You'll find the lcm (least common multiple) and gcd (greatest common divisor) functions in the MATH NUM menu. Press MATH, right-arrow, and select the desired function.
Jul 07, 2011 | Texas Instruments TI-84 Plus Silver...
GCD-700 does not turn on. Internal fuses OK
If the fuse is intact the fault must be checked from the power supply to the main motherboard section.
Check if the power supply works, if not check the SM drivers .Click the link below;
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 17, 2011 | Adcom GCD-700 5-Disc CD Changer
Algorithm for gcd of two numbers using the function recursion
function gcd(a, b) if b = 0 return a else return gcd(b, a mod b)
May 13, 2010 | Computers & Internet
I need to replace the laser assembly on a ADCOM GCD-750
I thought it used a KSS-240 which is a Sony laser.
# will be on the laser and Mcm has it for I think $35
Apr 16, 2010 | Adcom GCD-750 CD Player
What is GCD-R540C cd rom speed
It is a VERY OLD CD reader. it;s speed is 4x normal.
Mar 19, 2010 | LG GCD R540C (GCD-R540C) Internal 4x...
How to do gcd on the ti-84
Press [MATH] Right arrow to [NUM] Scroll down till you find 9:gcd( [ENTER]
The command will appear on Home screen as gcd(. You enter first number, then a comma, then the 2nd number, and close the right parenthesis
Exemple gcd(3,21) [ENTER] gives 3 as result.
Hope it helps
May 25, 2009 | Texas Instruments TI-84 Plus Calculator
Need manual for both Adcom CD players I own GCD-750 and GCD-575
For the owner's manual for this legacy(old) unit go to;
http://www.adcom.com/data/manuals/gcd_750manual.pdf
For $350 you should be able to buy 5 new units- at least.
Apr 02, 2009 | Adcom GCD-750 CD Player
Adcom GCD 700
Is there a specific question or just generalities? Open up the top and the Sony optics number should be right on the optic assembly. I believe that it uses a KSS-240 optics assembly. What else do you need?
Dan
Mar 30, 2008 | Adcom GCD-700 5-Disc CD Changer
Adcom gcd-600 won't play
If I understand your issue, you press play and the player does not recognize the disc, the optical pickup may be defective. I suggest you contact an Authorized Adcom Service Center. For further questions, contact Adcom directly.
Dec 02, 2007 | Adcom GCD-700 5-Disc CD Changer
Casio Scientific Calculator Fx-570 Fx570 Fx570ms Wrty Logo
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
