Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Dont know how to get cable channels , i just get local channels.
Just got a d52w20 hooked it to the cable into the screw in antena port. i just get local channels. what do i have to set to get cable stations? does it have to be set on the tv or can i do it from the remote?
  • garytows911 Jun 18, 2009
    some of the wording was different but it was good enough to let me know what to do and i got it . thank you
    President:
  • 563 Answers
Hello.
It sounds like you need to change a setting before running the auto or channel scan. On the same menu screen that has the option for running the channel scan, you should see a setting that has next to it the word "AIR" or "ANTENNA". If this isn't changed to "CABLE" or "CATV" then the TV will only scan for a limited number of channels because it assumes you have an antenna hooked up to it instead of a cable line. This is the same for all TVs. Anytime someone runs a channel scan on ANY TV and they only pick up a limited number of channels, they need to change the setting I've described. And remember, it will be on the same menu screen that you go to in order to run the channel scan.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
P.S. On some TVs, autoscan is called autoprogram.
Posted on Jun 18, 2009
2 Suggested Answers
  • 59 Answers
SOURCE: I JUST GOT A D52W20 HD TV.I SCREWED THE CABLE
Before you bought your new TV, was the cable connected to an older TV, and was it working?
When you say you screwed the cable connection to the antenna input, did the cable come directly from the wall, or did it go through a cable box first. If it came through the wall without a cable box, it's possible it's not an active cable account, and you're only getting over the air signals for your local channels (and nothing through the cable). Or, your cable signal might have been analog only, and with the transition this week to digital TV, maybe you're no longer getting the channels broadcast properly.
If you are a cable subscriber, then this problem should be reported to the cable company, and they can do further testing to see what's wrong with your signal.
To hook up antena-do you need a special cable
No,buy a indoor digital antena have a wire already just plug the wire into the Ant. hole screw it in.Go into the tv menu goto SETUP.Go down to Ch.enter pick AIR enter again for scanning for free air broadcasting channels,after all done scanning.That it tv now have all free air broadcasting channels.
Jun 09, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
I don't understand the manual! How do you get any channels tuned in on the Technika LCD19-910
on all tvs there is a menu pannel find the menu button on the remote or tv could also be called setup button look for channel option or antena cable option (no on most of the new tvs it is an auto scan) and select that option it will scan throught the channels and auto add the ones that get reception say if ur using an antena
if u are trying to hook up a cable box or sat box through the antena coail wire at the same time u can not have them on so to scan for antena channels turn off the sat recver and cable box scan for channels because the sat box and cable box destors the singnal when on the same time with the antena u will proble have to go back into the main menu where yu selected the channels and manualy add channel 3 or 4 which is what runs the sat/cable box if ur using the antena hookup on the tv
if u are hooking the sat/cable box or dvd player to red gren blue or yellow white red hook up's they will be under a diffrent source chanel which u can usaly get to by hitting the input or source button on the remote
Jan 15, 2011 | Televison & Video
Our cable was turned off today and we get no channels on our tv. Shouldn't we be able to pick up some analog channels?
If you have an extenal antena and your tv is digital you should be able to get local chanels. If you dont you can get a converter box about $35.00 and get a good external antena that should do it.
Thanks,
Dec 18, 2010 | Vizio Televison & Video
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
I can;t get the tv to find the local channels not on cable... I set it to air and preform an auto channel serch and it finds nothing
U have no cable right?U have a roof antena?Or get a good digital antena.Hook it up.Get in the tv menu go to SETUP go down to CH. pick AIR and let it scans to complete,u will get all the Local channels,and other free AIR channels when it scan it complete.
Apr 01, 2010 | Polaroid FLM-4234BH 42 in. LCD HDTV
Cannot receive channels past 99
Is this free over the air signal?Get a better antena like a roof antena or digital antena.Rescan again after everything hook up.If this Cables,satalites,or telecom signals,unplug,replug the box for bootup and software
upgrage,go to ur tv menu make sure it on cable setting,rescan it again to get all fresh channels.
Nov 04, 2009 | Symphonic ST420FF 20" TV
I JUST GOT A D52W20 HD TV.I SCREWED THE CABLE CONNECTION TO THE ANTENA INPUT. THE ONLY STATIONS I GET ARE LOCAL CHANNELS BUT NO CABLE CHANNELS. WHAT DO I HAVE TO SET ON THE TV OR WHAT DO I HAVE TO PRESS ON...
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I dont have satelite or cable how do i get tv channels?
you can go and get an indoor digital antena from any electrical store and hook it up. you can then scan for the local channels.
Jun 18, 2009 | iLO 3200 32 in. LCD Television
Cable antena ready input repair
Purchase replacement at radio shack, disassemble the tuner, and solder the replacement in. It is not a screw in.
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
351 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
