Question about Android Apps
I need my computer to identify my tablet so i can send the files to fix my firmware
And the files
How do i do a factory reset on my Gemini D7
The Gemini tablet line performs factory resets and firmware updates with an SD card. Performing a factory reset requires writing files to an SD card with a computer, then starting up the tablet with the SD card present in it. Be aware that it will erase all data on the tablet, but with it in a boot loop, that may be a moot point.
Knowing the specific model number of your tablet is critical. Flashing the incorrect information can cause worse problems than you are encountering now. Rather than send you to the D7 GEM7007 page, I will give you the general page that leads to all the possible tablet results and directions. Look for the link that matches the Model Number, not just the name.
Factory Reset Original Firmware ROM Image Flashing Instructions
You will most likely need:
An SD card appropriate for the tablet (SD, MicroSD, Etc)
A reader for the card for your computer (Attached reader will handle SD and MicroSD)
The ability to get the Tablet to completely turn off to start the process.
The first two can be purchased. The last one is up to whether the tablet has a hardware fault. If the tablet has any kind of broken hardware inside it (wear and tear, aging, or damage) the process may not work. In the event of hardware failure, replacement under warranty or without warranty may be the best solution.
Apr 25, 2015 | Android Gemini Tab
How do i reset my skytex skypad alpha 2 because ive forgotten my pattern lock?
How do I reset my password on my tablet?
  1. Download the re-flashing program onto your computer by visiting the Drivers & Downloads tab.
  2. Under "Firmware Downloads," select your tablet's firmware file.
  3. Select "Download" for the re-flash program and instructions for your PC. When the download is completed, follow the instructions to perform a firmware re-flash.
click on dl on your computer and install on tablet,,
SKYPAD Alpha 2 Product Support Overview SKYTEX
Jan 28, 2015 | Skytex Sxsp715a Skypad Alpha 2 7inch...
I am trying to fix a friend's digital2 tablet the s/n is m961gpl1312 and every time it starts up it goes to the Android recovery page and I've tried to factory reset it and then restart it but it still...
you probably will need to update the firmware
D2_961 Firmware Update Instruction:
1. Download the D2_Firmware in the link below
2. Use an archiving software (Winzip, WinRar, 7 zip etc.) to extract the Firmware Update package and export it to your computer's local disk (ex. C:\)
3. Open up the zip file and there will be 3 folders as shown in image
4. Open "Pad Product Tool 1.05_02" folder and click on "setup.exe" to install update tool.3-284x233.png4-284x233.png5-284x177.png
Click "Next" all the way until the program starts installing. Click "Close" when the software has done installing.
6. Click the 7.png icon and choose the firmware file "jellybean_atm7029_m2909_131216.fw" from the "FW_m2909_961_1115_1216" folder.
7. When the firmware file loads, it will show up on the PAD Product tool.
8. Now, click and hold down the "Volume - "key on the tablet.
9. While holding down "Volume - " key, connect the tablet to a PC using the USB cable.
10. Still holding down "Volume - "key, use a paper clip (or a small pin) and press the "Reset" button on the back of the tablet ONCE (and let go)
11. The 9.png icon will turn into 10.png . Click it to start the firmware update.
12. After the update is complete, remove the USB cable first, then turn on the tablet.11.png
13. The initial start up time may take up to 50+ seconds.
14. After initial start up, tablet will require a reset. Please press and hold the reset button for 10-15 seconds to reset the unit.
http://cloud.d3reaction.com/public.php?service=files&t=2ff2083703cca9cfa4050bd47a793864&download
Jan 19, 2015 | Digital2 Tablets & eReaders
When sending photos to a PC they are being received in one continuous reel and not individual pictures with file name
Have you looked into using an app called 'Push Bullet'?
It allows you to send files, links, documents, etc from one device to other; I often use it to send images, and such from my phone directly to my computer, or my wifes phone for that matter. The computer or device you want to send to will need to have the program installed as well but it works very well.
FWIW
Sep 24, 2014 | Apple iPad 32 GB 3G Tablet PC
Haier hg 9041 boot up problem
Did you get it fixed or did you send the tablet back? I could not get mine fixed and I finally paid attention to another forum and I fixed it with that download. I was zipping the file then unzipping it then putting it on my sd card and it does not work that way. I saved the new firmware straight to sd card put in tablet and boom I was up and running in ten minutes. Just be patient with it cause it will act like its doing nothing but it is.
Feb 09, 2014 | Tablets & eReaders
Proscan Tablet
well its sounds like the problem starts from when you downloaded the stock firmware and it basically affecting the touch sensivity of the tablet ,and you send when you flashed it still the touch remain the same meaning it didnt work fully .so maybe you need to flash it again and restore factory settings
Jul 02, 2013 | Computers & Internet
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Mar 08, 2013 | Tablets & eReaders
PROBLEM WITH TABLET CRUZ READER R101
To update the firmware you can follow the directions here http://www.ehow.com/how_7890482_update-cruz-reader-firmware.html
I used a similar method when I had my Cruz Reader R101. This process is called "side-loading"
You will have to download a file to your computer (not your tablet), remove the SD media card from your cruz, then transfer the downloaded file from your computer to it, then replace the SD card to your cruz.
Also you can download the user manual here http://www.retrevo.com/support/Velocity-R101-Tablets-manual/id/23894dj696/t/2/ which shows how to remove the card, and this is a great reference to keep on your reader. For example, page 14 shows how to transfer files to and from your reader. Good luck!
Jul 21, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
Android Apps Logo
73 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
