Question about Parkinson Cowan SG340 Gas Kitchen Range
No ignition on grill - Parkinson Cowan SG340 Gas Kitchen Range
How do i chane the ignition button on the gas grill
Contact manufacturer for new igniter, new igniter should come with instructions for replacement. It should be fairly simple, disconnect two wires and retaining nut and then replace with new igniter, connect wires and screw on retaining nut.
Apr 26, 2014 | Char-Broil CharBroil 4637318 Grill
I have q300 grill. It will not light with the igniter but wih match.
Make sure there is no food on the igniter tip. If not, you need a new igniter.
Oct 13, 2012 | Weber Stephen Products Q300 Gas Grill
Where is the ignite button located
Hi phillzy21
If the main grilling burners don't ignite, try lighting them several times using the snap ignition. If that doesn't work, try using a match. In humid and windy conditions, sometimes the snap ignitions do not work properly. Make sure that the hood is fully open. Also, ensure that your gas is turned on and that the valve is fully open. Next, take out both the heat distribution plates and cooking grate. Turn the grill backwards, and hit the snap igniter a few times and look for a spark. If you see a spark, the igniter is working properly.
Bud
Oct 02, 2012 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Battery igniter
If you have an electric igniter, you need to locate where on the side of the grill the battery (e.g. AA size) that generates the electricity for the igniter is located. Replace the battery, and assure the contacts are cleaned (as they may have corrosion if grill located outside). Then check where the ground of the igniter is connected to the grill. I unscrewed the screw where the ground was located, cleaned off the corrosion with a fine sandpaper, then reconnected it to a new screw on the cabinet.
Jun 01, 2012 | Weber Genesis Silver A Grill
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
I have a char-broil Grill where the ignition wire came loose and do not know it came from
it come sfrom the ignitor on the burner or off the sparker /ignition button
May 20, 2010 | Char-Broil CharBroil 4637318 Grill
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
Igniter Stopped working
Igniter could be shot. Take out igniter and put near something metal. Push button to see if sparks occur. If not igniter is no good. If this works, the end of wire that is near wear the igniter sparks to light grill could be to far away from metal, bend to get closer to metal, so it will spark, or end could be covered with grease, clean end and try for spark again.
Jun 14, 2009 | Weber Performer Grill
Weber Summit Grill Igniters
I contacted Weber and they sent me a complete igniter system. I will have to install it.
Oct 06, 2008 | Weber Genesis Gold B Grill
Weber grill
Can you tell if the gas is flowing? Its either dirty or perhaps your regulator got damaged.  I'd check that out.  Above all else, though, be careful!
Dec 05, 2007 | Weber Genesis Silver B Grill
Parkinson Cowan SG340 Gas Kitchen Range Logo
20 people viewed this question
Top Parkinson Cowan Kitchen Ranges Experts
Paul Carew
Shehu Pro
Shehu Pro
Tim Whalen
Are you a Parkinson Cowan Kitchen Range Expert? Answer questions, earn points and help others
