Fire Pits Outdoor Heirloom Heating Heater Slate Deep Firepit Bowl with Dome Scre Logo
A
Anonymous Posted on Apr 13, 2014
Firepit doesn't work - Fire Pits Outdoor Heirloom Heating Heater Slate Deep Firepit Bowl with Dome Scre
Turns on for 1 minute and gets Er - I cleaned filter
It may be getting too hot and activating the safety shut off. This may need a new board. I have never worked on one of these but it has to be fixable. Depending on the cost of the unit as to whether or not it is worth it.
Fan works but no heat
look to see if the safety fuse is open you can do that by using a continuity test on the heating element.
1helpful
2answers
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
3helpful
2answers
I have a I heater that will not turn on. Last time it worked fine. What should I check ?
first check the outlet its plugged into to be sure there is actually power there, if not check your breaker box, it may have overloaded the circuit and popped the breaker. if all good there, check the unit for a fuse, which may be blown.
What is a thermocouple replacement for patio heater metric threads
Not sure, Most universal kits will work. Take old one with to get replcement, sometimes depends on milli-volt out put also.
My infrared heater home heater makes a screeching noise
That will be the fan and dry bearings on the motor. Spray with WD40 which although is a Water Displacement spray, it will do the job.
Eden pure beeps 3 times, and then it will not work
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Top Fire Pits Patio Heaters Experts
deton8 von Splosion
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Fire Pits Patio Heater Expert? Answer questions, earn points and help others
