Question about Refrigerators
Lg gwl227ybqa The dispenser light keeps flashing and the relay at the top of the fridge is clicking but stops when the freezer door is open
SOURCE: Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Posted on Sep 07, 2007
  • 87 Answers
SOURCE: GSH22JSRE SS not cooling
I would strongly advise seeking a competent fridge guy. If it is the compressor (which sounds like a distinct possibility) they should be able to identify it very quickly. They would then be able to give you a cost on replacement. Alternatively you could try throwing it back at where you got it from and see if there is an extended parts only warranty. Some manufacturers now have three or even five years warranty on major components (ie compressors). Although there is no guarantee of this, its always worth a try, you might get someone sympathetic to your plight, due to the young age of the cabinet. Hope this is of some if not limited use.
Posted on Sep 11, 2007
KikkaMikko
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
Posted on Aug 11, 2008
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
erpaalai
  • 999 Answers
SOURCE: LG fridge/freezer rumbling/vibrating sound
Check your defrost components. The fan is hitting the frost buildup and will shut off when the door is opened so as to not circulate the warm air. The heater or the timer is not doing a proper defrost cycle.
Eric
Posted on Jun 24, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Water is no longer coming out of the water dispenser. The fridge is plumbed in and water is getting to the water filter and the ice maker but not coming out of the dispenser.
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Jul 16, 2008 | Samsung Refrigerators
LG Fridge / Freezer GWL227YBQA
sounds to me that you have either a sensor problem or a main board issue. to avoid spend money and the intricasies of trouble shooting, call for service. Sears has a Service Smart Agreement that is reasonable and would cover needed repair up to 500.00
May 20, 2012 | Refrigerators
I`v got an american whirlpool fridge/,somehow the freezer door was left open (not sure for how long),but when discovered lights inside were flashing/clicking.the water dispenser/temperate control on the...
A serious problem You have to take assistance from a technician. Due to overload as the door was left opened either the compressor motor or the condenser is burnt out. Please have it checked up. You will not be able to repair it yourself as it may require replacing parts.
May 02, 2010 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
My fridge is making a loud nosies and it is not stopping
that is the auto defrost fan working,nothing to worry about.
Apr 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The lights on the Ice and Water Dispenser flash
On left top side of door, remove cap and disconnect wire. This will turn off the control board on front of fridge and fridge will still run. Then follow this link - http://www.liny.net/MaytagIce2O.htm - click on frig picture at right and you will get step by step instructions with parts and tools you may need costing around $20.00 for a do it yourself fix.
Aug 19, 2009 | Maytag MFI2568AE Side by Side French Door...
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge and freezer not cold. Loud buzzing and clicking intermitently. Lights flashing to say door is open and all freezer temperature lights are all flashing too
Read this article on Compressor Relays to understand the problem you are having.  It will explain in detail what to do to repair your machine.
Thanks, Bill
Nov 09, 2008 | Whirlpool Refrigerators
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
