Question about Nordic Track NordicTrack C900 Treadmill Walking Belt
Treadmill turns on, console lights up, but belt will not move
Golds gym treadmill 420 belt will not move but panel works and elevated.
hi Mary.
If you flip on the switch, set the speed and nothing happens, your treadmill is an unhappy camper. Troubleshooting involves putting on your inspector hat and taking a tour of the belt. You may have to proceed to the console if that doesn't solve the matter. Belt Tension If the belt is too tight, it could cause enough tension that the motor can't turn the belt. This is most likely the cause of your belt not moving if you recently adjusted the belt tension due to slippage. Lift the edge of the belt. If you can't raise it at least 2 to 3 inches off the walking deck, the belt is too tight. Follow the directions in your owner's manual for loosening the belt. You will need an Allen wrench to loosen the rear roller adjustment bolts.Belt CenteringA treadmill belt can shift to the right or left over time. If it shifts enough, this may cause the belt to stop moving. Stand at the back end of your machine and inspect the belt. If it has shifted, you will need to center it by turning the rear roller adjustment bolts. These bolts adjust both the tension and the centering of the belt. Follow the instructions in your owner's manual that explain which of the two bolts you need to tighten or loosen to shift the belt back to the center.Console WiresHorizon Fitness recommends checking the console wiring if your treadmill belt doesn't move. The console wire connects to the main wire that runs down the inside of the treadmill upright to the motor board. Make sure the connection between the two wires is secure. The connectors usually snap into each other. Disconnect and reconnect the wires. Make sure the wire that runs through the upright isn't pinched or twisted.Additional Options If the troubleshooting does not get the belt running again, you may have a tight motor belt or a bad motor. You will need to remove the motor hood to access these parts of your machine. If your treadmill is still under warranty, contact the manufacturer for a professional repair. You may void the warranty if you attempt to work on the motor yourself.or read up some more at this link. Golds gym treadmill 420 belt will not move Google Search
Dec 12, 2017 | Exercise & Fitness
Image 19.0Q Treadmill. Console lights up but how to unlock the buttons?
If you wish to get some details about treadmill repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 27, 2016 | Exercise & Fitness
You turn it on, and the display lights, but the belt won't move at all.
Does the console count down ?
If so and belt wont move then you have a problem with the LCB.
Oct 07, 2013 | Icon Image 17.5 S Treadmill
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
My pro form treadmill - panel lights come on but belt not operating? Any ideas how to repair or who would call out - Derbyshire area? Thanks
If the light are on and when pushing the console start button the oval track lights (on the console) should move. If not, then your console is bad. On most Pro Form consoles you have to replace the entire console. Individual parts are not available.
Jul 28, 2010 | Proform Exercise & Fitness
I have a proform xp 550s treadmill. The belt
change drive belt proform xp 550s treadmill
Aug 26, 2009 | Exercise & Fitness
I have the horizon elite 507 treadmill, how do I move the tread back to its normal position using the blue tool? thank you
Is it all the way over to one side? Is the belt damaged on one side? If it is damaged you will never get it to Track correctly.
If it is not damaged, then start the treadmill moving at about 2.5 mph, if the belt is all the way to the right then turn the right rear roller adjustment bolt, clockwise one full turn, and wait. did the belt move over a little? if yes the increase the speed to 5.0 mph and observe.
Make small adjustment from one side only until you get it straight.
Jul 05, 2009 | Life Fitness T3 Treadmill with Advanced...
Nordic Track NordicTrack C900 Treadmill Walking Belt Logo
20 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
