Question about Reiker Room Conditioner Ceiling Fan with Heater RRC12001
Remote for reiker fan quit working
Remote for heater fan quit working tried to reset with no success. Is there a fix for these or do you need to purchase new one?
4 Suggested Answers
SOURCE: reiker room conditioner
Reiker Corporation distribution fan motor is the largest and best available in the ceiling fan industry and carries a lifetime warranty.
Posted on Jan 17, 2009
called reiker, and they sent me a new thermostat for the fan. installed it and problem solved
Posted on Feb 02, 2009
  • 3 Answers
SOURCE: Reiker ''room conditioner'' heater stopped working
I've also had this problem. Solved it with the reset button on the back of the remote. It's under the battery cover, next to the dip switches.
Turn on the remote, with heat. Then, at the wall switch or circuit box turn off power. Wait a few minutes. Restore power and within 30 seconds with remote in range of fan hit the reset button. You should see a countdown from 5-0 on the remote screen.
I did this and the heat started working again.
Posted on Feb 17, 2011
When i turn on the power switch fans on high and the light is on the remote does nothing heater on it stopped working a yr ago
Call the company, then buy another fan without remote control or heater
1-800-283-7031
Reiker ceiling fan warranty is 1 year limited:
http://www.buyreiker.com/default.aspx?page=10
Reiker troubleshoot is zero help:
http://www.buyreiker.com/default.aspx?page=51
Troubleshoot section page 15 of manual is zero help.
http://www.buyreiker.com/manuals/ownermanual-e.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 23, 2012 | Reiker Dryers
Reiker ceiling fan - does not turn on - theres is power to unit - maybe remmote is bad? how do i change code
Before trying to change the code, have you tried changing the batteries? Both in the hand held remote and the one in fan housing? If so, and that didn't help, make sure the batteries are turned in the right direction and fitting tightly.
Will the fan operate without using the remote control?
Feb 19, 2011 | Reiker Room Conditioner Heater
I have had a Reiker Heat/ cool fan for 3 years and have had no problems, till now. All parts are working ,lights , fan, remote, but I have no heat. How do I fix this. K.
I had the same problem and fixed it with a reset. The reset button is on the back of the remote next to the dip switches. You have to take the battery cover off to see it.
Turn on the fan with heat using the remote. Then, leaving the remote turned on, turn off the fan at the wall switch or circuit breaker. Wait a few minutes and turn the electricity back on. Then, within 30 seconds, and within range of the fan, press the reset button. You should be able to see a countdown from 5 to 0 on the remote screen.
Once I did this the heat began working again.
Jan 07, 2011 | Reiker RRC1200001 Heater
My new rieker fan stopped blowing heat- the fan works --not the heater
I had the same problem with my fan and solved it with a reset. The reset button is on the back of the remote next to the dip switches. You have to take the battery cover off to see it.
Turn on the fan with heat, even though the heat doesn't work. Then, leaving the remote on, turn off the fan at the wall switch (or circuit breaker box). Wait a few minutes. Then turn on the power and within 30 seconds, press the reset button. You should be able to see a countdown from 5 to 0 on the remote screen.
Once I did this the heat started working again.
Jan 05, 2011 | Reiker Ceiling Fan/Heater Combo Utility
Reiker room conditioner
Jan 27, 2009 | Reiker Room Conditioner Ceiling Fan with...
Dec 14, 2008 | Reiker Room Conditioner Ceiling Fan with...
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Fan and light no longer turn on
possibly the thermal overload sensor failed internally? as indicated in the instructions there is a overload sensor and thay will typically fail in others appliances.
Oct 30, 2008 | Reiker RRC120004 Brushed Steel Ceiling Fan
Reiker Room Conditioner Ceiling Fan with Heater RRC12001 Logo
54 people viewed this question
Top Reiker Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Reiker Heating and Cooling Expert? Answer questions, earn points and help others
