Question about Fujitsu PlasmaVision P50XHA40US 50 in. HD-Ready Television
How to apply sound back to a fujitsu
The tv had surroud sound, cant get sound from tv itself help
How to connect fujitsu 5515 laptop to panasonic tx-l22D28BP TV
Hi there
According to the specification here:
http://www.jetron.com/dwnld/fscesprimomobilev5515.pdf
the Fujitsu laptop only has a VGA output for an external screen. It will be necessary therefore to connect this with a suitable VGA cable to the appropriate connector on the back of the TV, and the audio output from the computer to the appropriate audio connector on the back of the TV.
I found a manual for the TV here:
PANASONIC TXL19D28BW Operating Instructions Manual
It does apply to the 22 inch screen model as well. and by clicking on the green download button near the top of the screen, you can follow the instructions for a free copy of the manual which gives clear instructions for your connection requirements.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Mar 02, 2015 | Panasonic Televison & Video
No Image displayed
If you get no sound but the hum, there is a problem on the power supply panel inside this TV set. The only way to repair this set would be to replace the power supply panel. But before you condemn the power supply panel, open the set and disconnect the back-lite inverter supply and make sure that is not loading down the TV sets power supply. You would not see a picture if you disconnected the inverter circuit, but the sound should come on. Good Luck
Jun 30, 2007 | Fujitsu Plasmavision PDS-4233 42 in....
Hi, I just bought a blu ray home theatre system and hooked it up, the surround sound sounds great but it only works when my watching a movie with the blu ray player... I hooked the blu ray player to my tv...
If you want everything to have surroud sound, it all has to run through your system and you select which function to use. Yes it sounds like improper connections.
Sep 03, 2011 | RCA Audio Players & Recorders
I have a fujitsu siemens lifebook E7010 laptop and the problem is this : When I switch on power the system goes ON but with a black screen and the small LCD is showing the start logos CD player is working...
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 22, 2011 | Fujitsu LifeBook E7010 Notebook
Picture but not sound on my Fujitsu Plasmavision. TV used to be hooked into a control 4 system that handled sound but now no system is attached. Help! Tried adjusting the sound settings for a while last...
Picture but not sound on my Fujitsu Plasmavision. TV used to be hooked into a control 4 system that handled sound but now no system is attached. Help! Tried adjusting the sound settings for a while last night to no avail.
Apr 14, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
Help!!!!! I'm housesitting and cannot get the Fujitsu flatscreen to turn on. I've changed the remote batteries, but the red standby button the the left bottom of the TV screen keeps blinking. Can you help...
1. Try using the on/off switch that is on the TV itself and use the other buttons on the TV for sound and channel etc.
2. You might need to try a replacement remote.
3. On some remotes you need to press the "TV" button and, then, the power switch on the remote.
Oct 30, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Oct 26, 2008 | Sony DAV-S400 System
Rxv-663 cant get surround to hook up to tv
connect your component to audio out from tv to your audio in at the back of your component
Jun 17, 2008 | Yamaha RX-V661 Receiver
Fujitsu PlasmaVision P50XHA40US 50 in. HD-Ready Television Logo
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
