Question about JVC TH-M505 System
No power to the player - JVC TH-M505 System
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
I'm setting up my new Roku and when I get Roku updates it says cannot connect to Roku (error code 011) try later
If you are attempting to setup your Roku player and you see a Code 011 error, this means the Roku player momentarily lost connection to the Roku update server. There may be a chance that Roku servers are not available due to a scheduled maintenance. When this happens, try again after a short period of time. Then just perform a power cycle of the Roku player with the instruction below. You should be able to continue where you left off.
To resolve this do the following:
  • Power cycle the Roku player by removing the power connector from the back of the Roku player. Wait 30 seconds, then reconnect the power. Wait for the player to restart, then follow the on-screen instructions.
  • If power cycling the Roku player did not resolve the error then a network power cycle might.
    • To do this remove the power connector from these devices. (note that your router and modem may be one physical unit)
      • Roku player
      • Wireless router
      • Modem
    • Wait 30 seconds then reconnect the power connectors in this order, waiting 1 minute between each device to allow it to fully boot.
      • Modem
      • Wireless router
      • Roku player
    • Follow the on-screen instructions from the Roku player and TV.
If none of the above steps worked then a reset of the Roku player may be needed. To reset the Roku player:
  • Find the reset button.
    • Examples of where to find the reset button are below.
  • Press and hold the reset button for 30 seconds then release.
    • The Roku player will then restart.
  • Aug 20, 2014 | Roku 2 XD Streaming Player 1080p (3050R
    How do you reset a frozen player?
    Slide the power button on your SanDisk Sansa MP3 player up.
  • 2 Hold the power button on your Sansa in the up position for about 15 seconds. This action serves as a powering down of the Sansa device.
  • 3 Wait for your Sansa MP3 player to restart and let go of the power button. Actions taken during your last operation since powering down normally have been deleted and your player is now reset.
  • Feb 08, 2012 | SanDisk Sansa Clip MP3 Player
    WHEN I TRY TURNIN IT ON IT JUST STAYS ON THE SANDISK 256MB WELCOME SCREEN HOW CAN I UN FREEZE IT?
    Reset the device. 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
    Power cycle the device.
    The power cycle discharges excess/residual power from the player; with the use of a new battery, it should be able to power on the MP3 player properly.
    STEP 1 - Remove the battery STEP 2 - Power cycle the player 1. Connect the player to the PC. 2. Leave the device connected for about 2 minutes.
    STEP 3 - Turn on the device 1. Unplug the player from the PC. 2. Insert a fresh AAA battery into the player. 3. Turn on the player.
    Dec 29, 2010 | SanDisk SDMX1 MP3 Player
    I have philips MP3 player that isnt powering up
    from my experience, I think your player is having a power problem. It must have received excess voltage/irregular power supply which has damaged an IC or capacitor on the power board of the player.
    Sometimes this excess power supply might damage the player's main board. This is why it is advice able that you use step down for your player, because DVD player don't need excess power as something might be damaged.
    To solve this problem, you will be needing a meter. Open the player, use the meter to read the components on the power board as it will help you discover the component that got damaged and you can then replace the bad component.
    But if you do not have the knowledge of fixing this problem, you might be needing the help of a service technician.
    Take care.
    May 13, 2010 | Audio Players & Recorders
    Won't turn on.
    "Player is getting power. (It's) making a faint sound and the output jack is flashing but shows nothing on the display"
    So, it is obviously NOT 1, 2, or 3 above. It IS getting power.
    The first thing I'd try is a re-boot, try unplugging the unit and waiting about
    Feb 08, 2010 | LG BD390 Blu-Ray Player
    Dvd player won't work when plugged in with car adapter
    1 st Check and see if you have power coming out the power plug.
    2nd. Ckeck and see if the fuse is ok in the unit.
    3rd Check and see if your cig ligter works in your power outlet.
    Jun 10, 2009 | Zenith DVP615 Portable DVD Player
    Will not power on
    Try opening up the player, and replacing the small glass fuse on the tan board that the power cord attaches to.
    Jan 24, 2009 | RCA DRC247N DVD Player
    DVD Player does not turn on
    Check the power connection on the player. Wiggle it to see if the ON lite blinks. Polaroid has had problems with this connections. ON lite will indicate that the fuse probably is OK. But there may not be complete power to the whole player because of a bad power connection.
    Dec 01, 2008 | Polaroid PDM-0824 Portable DVD Player
    JVC TH-M505 System Logo
    23 people viewed this question
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
