Question about Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
Hi! Have had our Asko for several years & has always worked fine. Now it will not fill with water. Everything works as before, the power is on, the water line is fine, the door closes, the push start button clicks, but then there is no water fill, & no action at all. Would greatly appreciate any & all input! Thank you so much! :0)
  • 1 more comment
  • chidorii Jan 05, 2008
    I have the same washer and but it fills up with so little water my clothes are damp but barely washed after a full cycle and still full of detergent.
    In the beginning I was fooling around with the washer and opened the little compartment in the bottom front of the washer and twisted a knob off ... a bunch of water leaked out before i put the knob back on ... is that bad? did that cause the water level in the washer to drastically be reduced?
  • igtheon Jan 23, 2008
    Machine worked fine for 4 1/2 years but stopped working.When the start button was pushed the machine clicked and then nothing.I bought a new circuit board for $240.00 and the machine worked for one wash only and now back to the same problem.Could'nt get any info out of Asko they want me to take it to their authorised service man.
  • lalaladada Feb 09, 2008
    When i press start on my washer i can usually hear the water start running.. Now when i press start nothing happens.. The door is shut and on correct setting
    Sergeant:
  • 351 Answers
The carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Posted on Mar 02, 2008
Asko w6021 started to fill with water and then shorted out the power any suggestions?
not much help sorry but is possibly the motor shorting, try turn the drum a little before you reconnect and see if it still shorts. I have had an element rupture and therefore be soaked in water and thus causing the short. Sorry I cant help more
Mar 04, 2013 | Asko W6021 Front Load Washer
Tip
Asko W6021 would not fill with water
Our W6021 front has had a couple of instances where it would not start the fill cycle as usual. Normally it would be switched on,the relay would operate and the water would begin to enter the bowl. We tried a number of things including checking the hose and inlet filter for blockage. We then checked the outlet drain pump trap and found a coin and a drill bit lodged in the entry hole to the trap. Once the foreign objects were removed ,the machine operated as normal once again. I will be very careful in future to empty my pockets of metal things.
on Jun 15, 2007 | Asko W6021 Front Load Washer
Asko W6021 won't fill. It clicks and starts, but no water fills drum. I've cleaned drain trap but don't know how to clean inlet filter as suggested in manual.
The water inlet filters are inside where the hot and cold water supply hoses screw into the machine. Turn the water off, unscrew the hoses and they should be visible. However it might not be those causing the machine not to fill. If they needed cleaning the water would fill- but taking longer each wash.
If you confirm the filters are clear, it is more likely to be symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, or the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 20, 2011 | Asko W6021 Front Load Washer
I'm trying to start the asko washer for the first time and I can't get the door to lock. the start button is blinking??
HI there, the door on my front loader was very hard to close, but the service people told me to close it really hard - slam it! and it has been fine ever since.
Jan 02, 2011 | Asko W6021 Front Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Jun 09, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
677 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
