Question about Polar T31 Transmitter and Belt Set
Wrist watch won't show heart rate - Polar T31 Transmitter and Belt Set
escapement
  • 2334 Answers
SOURCE: replace battery in my Pola F11 Heart Rate watch
Yes, your watch will retain the same water resistance if you will not damage the rubber gasket. After replacing watch battery, clean that rubber gasket with lighter fluid(ZIPPO), place back in watch exactly as it was before and reassemble the casing.
If there are screws on caseback, do not overtighten them. At the same time do not leave them too loose.
Memorize how much power you needed to unscrew them and use the same to screw them back.
I'm recommending ZIPPO, because it would be difficult for you to get special cleaner and grease for gasket.
After cleaning the gasket with ZIPPO, rub a little bit of vaseline in to your fingertips and slide the gasket through them. That will do a good lubrication.
Don't forget to rate, please.
Posted on Jan 11, 2009
fitnessbalan
  • 59 Answers
SOURCE: Watch won't read heart rate
It could be the battery on the strap is not good. However just to be sure make sure you are wetting the strap and it is around chest, front should sit right about on the bottom of pectoral or chest, if you are female make sure it is under your sports bra the bra band will be over it. I would start warming up then hit the start button it should work.
Posted on Mar 08, 2009
fitnessbalan
  • 59 Answers
SOURCE: setting an hourly alarm on an F5 Polar heart rate monitor.
The only alarms available to use for that watch is your heart rate for exercise and a daily alarm. Unfortunately it does not have the hourly alarm feature. I wish it did I am a personal trainer and hourly chimes would help to keep me on time but my rs200 doesn't have the feature either. Sorry :)
Posted on Apr 22, 2009
  • 56 Answers
SOURCE: I need a user guide for the Polar F6 Women's Heart Rate Monitor Watch
You can find it here: http://www.pursuit-performance.com.au/polar/html/local/user_manuals.html
Posted on Jun 11, 2009
Coachphil
  • 347 Answers
SOURCE: I have a Polar F11 Heart Rate Monitor. The watch
There is a step by step guide in my tips and tricks of things to try with your strap. If none of these work and you are getting a signal from another source then you need to get either a new strap, a new sender or both. If you send the T-31 wearlink into polar they can run a diagnostic and see which is bad and sell you just the piece you need or a whole new chest piece.
Posted on Dec 16, 2010
My heart rate is right but my watch shows that i'm burning more calories then possible.
Make sure you have set all the other parameters correctly like your weight, etc.
Mar 23, 2011 | Polar F6 Wrist Watch
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
I changed the battery in the f6 . I had erratic readings. Now watch seems fine but it wont read heart rate,,,,I get no heart beat at all .
Check out my tips and tricks section for a guide on troubleshooting heart rate readings.
One other possibility if you changed the battery yourself (never recommended) is that some damage or moisture has gotten into your watch and made it impossible for the watch to read heart rate. This is a more common reason than you think and why all manufactures of Heart Rate monitors and other types of watches have you send them in to their authorized service centers.
Dec 08, 2010 | Polar F6 Wrist Watch
Polar F6, stopped counting calories and stopped showing heart rate. Buttons will not work and it reads Calorie? at the top
You will have to go to Polar for this problem. Sorry.<br /> <a href="http://www.polarusa.com/us-en/">http://www.polarusa.com/us-en/</a>
Aug 26, 2010 | Polar F6 Wrist Watch
My Polar F6 heart rate monitor is showing the day of the week as Wednesday, not Monday. How do I adjust the day on the watch function?
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Apr 19, 2010 | Polar F6 Wrist Watch
Wrist watch- at times the watch isn't showing
Manger de la marde vous êtes des crosseurs!
Vous mériteriez d'être poursuivis pour faire perdre tant de temps aux gens, pour vous approprier les solutions que les bonnes gens trouvent et ensuite faire de l'argent avec.
Oct 26, 2009 | Polar A5 Wrist Watch
Inaccurate Measurements of heart rate
Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
May 22, 2009 | Polar F6 Wrist Watch
I lost my m61 wrist watch! Need another.
I don't think they make that model anymore, you can check ebay I did see one on craigslist i saw a new one here .http://store.midwestmultisport.com/855.html or maybe upgrade to a new model :)
Mar 16, 2009 | Polar M61 Heart Rate Monitor Watch HRM M61
SPORTCRAFT Heart Rate monitor watch
Go to:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2016.pdf
Full user manual and instructions there to download.
Please contact again if this in not successful, if it is, your rating would be most appreciated.
Mike.
Feb 22, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Polar T31 Transmitter and Belt Set Logo
57 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
