Question about Garden
Suffolk punch manual
How do I start my Suffolk punch SP15s - is there a knack?
3 Suggested Answers
  • 3 Answers
SOURCE: maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Have you checked with the company that makes the mower for the manual? Hae you tried searching the internet to see if you find the manual there?
Posted on Dec 09, 2008
  • 110 Answers
SOURCE: i cannot start my Suffolk punch 43s petrol mower,
As far as I can tell, there are no downloads available. I eventually gave up and bought a copy from a mower museum. You will need to know the approximate age, as several diferrent engines have been fitted.
If you have the old red engine, the choke lever should be at right angles to the line of the carb IE pointing straight back.
The newer green engines are usually marked, but of not, remove the air filter and look into the carb throat. When the choke flap is CLOSED, the choke is ON IE cold start position.
As soon as the engie starts, move the choke to approx 50%, then fully open after 30 seconds or so.
If in good order, these engines are a 1-pull start. Fit a new plug, then spray WD-40 or similar into the OPEN carb thoat. If there is no sign of life at all, you have a coil failure (or possibly a points problem if it's ancient).
Posted on Oct 03, 2009
Any one know where i can source suffolk punch parts.
Hi try these sites www.ransomspares.co.uk. . www.mtmc.co.uk. . www,raidiy.co.uk..,.,.< discontinued spares <. good luck
Jul 29, 2016 | Garden
How much oil in a Suffolk punch 35s
Geoff, Check the attached links, manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.oldlawnmowerclub.co.uk/sites/default/files/opmanual/Suffolk%20Punch.pdf
Suffolk Punch OWNERS MANUAL
Small engine repair How to drain and change the oil in small petrol engine
Jul 02, 2016 | Garden
I have a new suffolk punch 17 sk but i am not getting a good cut it looks like its missingparts of the grass
Suffolks are designed for short grass,might u abrade this on a gauze area..use this with a care and soft hand.do regualar maintance surely advance Suffolks machine life.
May 31, 2011 | Garden
Replacement bottom blade for suffolk punchl lawn mower
Hi Keith,
You can find spares here:
http://www.espares.co.uk/search/lawnmowers/suffolk-punch/p/1116/2173
If you google suffolk + punch + spares you should be able to find more websites which supply blades.
Hope this helps!
May 30, 2011 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
I cannot start my Suffolk punch 43s petrol mower, can anyone tell me how the choke should be set?Or where can I download a free instruction manual.
Sep 18, 2009 | Garden
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Aug 30, 2009 | Garden
Maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Sep 14, 2008 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
