Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Jandy Laars blower will not turn on
I hear a click noise and nothing happens. No error codes or nothing
  • Scott Corey-reid Apr 14, 2014
    blower relay is clicking on. check the voltage getting to the blower. if the blower is getting proper voltage then you mayhave issue with the blower. If theres no pwer to blower, issue could be with the board
    Top Expert:
  • Jandy Master
  • 5,056 Answers
Check safety circuit
Posted on Apr 23, 2016
SOURCE: Pool heater will light then turns off
check gas pressure you should be getting about 10" water coloum
Posted on Feb 04, 2010
SOURCE: I have a Jandy Laars LX Pool-Spa Heater
You have a serious issue call a qualified heating or mechanical contractor sounds like a lock out or solenoid which is designed to shut off gas/flame for things like not blowing your backyard up is doing it's job. Or take the advice of a faceless stranger and hope you get it right 400,000 btu is about 7 x's the average home furnace so should be quite a boom
Posted on Apr 08, 2010
  • 2468 Answers
SOURCE: Jandy LAARS LT pool heater blows out the fusible
check for a heater that is leaking current to the water jacket and this would be a ground and if enough current leaks to ground it will open this link you can check this by undoing the heater,then if its ok then you know its the heater or by checking with an ohmmeter
Posted on Mar 23, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: Jandy Laars LT 400,000 Pool/Spa heater. Blows
Hello
You need to check the amperage draw of the motor,The only possibility is a shorted winding in the motor, or a bad motor.
Also check for correct voltage to the motor after the fusible links.Make sure the links are the correct size also.
Voltage and FLA or full load amps should be marked on the motor.You need to be within 5 to 10 percent of that number.
Posted on Mar 24, 2011
adamh294
  • 310 Answers
SOURCE: so we have the jandy
This heater wont start if the pressure switch is bad or clogged. Remove the pressure switch and clean it out really well, or just purchase a new one. It should only be $30-$50 depending on where you go to get it
Posted on May 03, 2011
Jandy R0317100 Gas Valve
make sure you have adequate gas pressure that is a safety so the heater will not self destruct must have 7.5 at least coming in check with the gas company to make sure you meter is big enough
Nov 15, 2013 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Laars LX Heater not starting
blower gets 120 vac. ensure proper voltage to blower to start
Jun 20, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
Laars LX 250 AGS Service error. Burners ignite the go out.
if connected 120 volt switch red and black wires its not rectification
Nov 17, 2012 | Jandy Laars Lt 250,000 Btu Heater
So we have the jandy laars lx.... we have had it for 3 years no problems we use it with pool and spa and its gas........ the buttons work you can choose pool or spa just fine but when you choose one... the...
May 03, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My Laars lite 2 won't turn on. I hear clicking noise three times in a row, then it stops completely. What should I check first then second?
check water pressure switch and copper tube could be clogged or pressure switch not opening all the way also check wires to pressure switch could be loose
Oct 09, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
I have a Laars Lite2 gas spa heater. I just replaced the Fenwal Electronic Eignition. When I turn the power on it starts the start-up process, the gas starts to flow, but no clicking of the igniter, just...
Check and make sure there is nothing fallen on the igniter or spider webs on it. Anything touching it can cause a problem. Make sure wire is not burnt going to igniter. Gas Valve will lock out after a time period if no Ignition.
Jun 20, 2010 | Jandy Laars Lt 250,000 Btu Heater
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
63 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
