Question about ElectroVoice . Speaker
No sound from EV SH-1502 ER 15" driver
These 1502 EV's sound great, but one has nothing out of the 15" low driver, the horn is fine, and loud, but no low hz from the low driver. I checked to make sure all wires are connected, and nothing looks burnt or out of place inside the cab. The terminals on the sub look fine, and the coil wires to the speaker are attached. When I link another speaker with this one, parrallel, the other speaker has full sound.
    Problem Solver:
  • 19 Answers
Either the 15" speaker is dead, or the passive crossover inside the unit. The simplest way to identify your problem is to remover the speaker that isn't working from the enclosure, and exchange it with the speaker that is working. If there's no sound still, it's the speaker itself that is the problem. If it works in the other cabinet, then put the "working" speaker in the cabinet you took the "bad" speaker out of, and if it doesn't work, then there's a problem with the crossover in the first cabinet. I believe you can buy a replacement crossover from EV. If it's your speaker, do a google search for "speaker re-coning" in your area - it's cheaper to re-cone the speaker than buy a new one.
Posted on Jun 18, 2009
Hi. My Mercedes C220 CDI horn has become faulty. Where it used to be a big loud horn, it now is a little beep... Any Ideas, much appriciated. Rgds WB
MOST CARS TODAY COME WITH A HIGH PITCH AND LOW PITCH HORN USUALLY MOUNTED RIGHT NEXT TO EACH OTHER , IT SOUNDS LIKE THE LOW PITCH HORN IS BAD . I WOULD GET ONE FROM THE DEALER AS THE "AFTER MARKET" ONES TEND NOT TO SOUND THE SAME
Jul 08, 2011 | 2002 Mercedes-Benz C-Class
Where can i buy a horn for a ev sx 300? how much?
You don't "buy a horn" as the horn itself is molded into the case and if the case is smashed that is fatal.
If it is the sctive element for the tweeter/mid you are after, the correct terminology is "compression driver". That should aid your search.
It is best to go directely to EV to get an exact replacement for this. Or try to find one at this site:
http://www.loudspeakersplus.com/parent_category/HFCD/High-Frequency-Compression-Drivers/1.html
They vary from about $30 to $500.
Sep 06, 2010 | ElectroVoice Sx300e
The horn on my 1997 Toyota Rav4, got real quiet. It still makes a low sound, but, it is not loud enough.
YOU HAVE TO HORNS HIGH AND LOW ONES... HIGH ONE IS SHORTED OUT.. LOW ONE STILL WORKS.. A NEW HORN IS ABOUT 45 DOLLLARS
Aug 23, 2010 | 1997 Toyota RAV4
I have an old set of EV 1502 PA Speakers. One of my Cabs the 15" driver stopped working... I can plug the Horn and the 15" Driver in Separately and they both work which I think means I have a problem with...
The crossover network is a combination of a LCR circuit. since all these arre passive components you will not have a problem to find the actual fault. Since you have confirmed with the drivers, the line in to the network from the speaker wires must be traced for continutiy, use a good multimeter. now check carefully on the PCB-printed circuit board.- for any track damage on it, if so loop and connect. The main driver is usually in parallel to the main line but with a croos over of a cpacitor and a series inductor. This will be the culprit, either it has come off from the PCB or open out by burning off. replace or reconnect. I am sure it can be sorted out easily by your carefully analysis. Hope this helps. Good day
Jul 19, 2010 | ElectroVoice . Speaker
Horn doesn't blow loudly on 2002 Escalade
It's possible that the horn exit passage is plugged with debris, but these things are usually a sealed unit which must be replaced. There should be two horns that blow together located one on each side of the radiator--if one is dead, the sound is greatly reduced. Some horns have an adjustment screw that will optimize the sound level. Hope this helps!
May 21, 2010 | 2002 Cadillac Escalade
Two EV SonicXS systems fried?
Fuses tend to blow when the circuit has been shorted. If the main amp device has gone open circuit it will do precisely nothing!
Jul 01, 2017 | Sonic EV SonicXS Computer Speakers
Eon 15 G2s, sound dropping in & out
Here's some links to manuals for you:http://beallcenter.uci.edu/facility/docs/EON15.pdf andhttp://www.jblproservice.com/pdf/EON-G2%20Series/EON15G2.pdf Hope they give you some info. Second hand prices are always nice but it's buyer beware. I don't have the amplifier schematic but what you are hearing might be some kind of protection circuit for the high frequency driver.
Aug 08, 2009 | Music
Monitor hp 1502 15"
Dear Client, you can download driver from the following link.
Monitor L 1502 15 Driver
Best regards
May 27, 2009 | HP Compaq 1501 15" LCD Monitor
2007 dodge caliber horn sounds distorted
Replace the horn(s). Some have one, some have two.
Mar 28, 2009 | 2008 Dodge Caliber
ElectroVoice . Speaker Logo
2,040 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
