Question about Canon PIXMA MX410 - multifunction fax / copier / printer / scanner color
Scangear code 5.156.61
I checked the USB Cable and Scanner is switched on but I keep getting the code error message. Thanks
SOURCE: scangear - scanning problems with mp600
windows XP instructions.can be easily applied to other operating systems
-turn printer/scanner on
-go to control panel
-click on system
-click on hardware
-click on device manager
-click on imaging devices
-right click on canon mp600 and choose updat driver option and then after that is done.click on scan for hardware changes
(below images provided)
this should make sure scanner work.. but if it still doesnt work then go back to the device manager and check if there are any hradwares with a yellow question mark beside them.if there is then right click on them and click update driver.
if that does not solve the problem try reinstalling the CD or go to the canon MP00 web page (google it) to dowmload the printer/scanner drivers. and repeat everything until it works or until you give up =). hope it all works out bye!
Posted on Apr 05, 2008
SOURCE: Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Posted on Apr 23, 2008
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
Hi
I had the same problem, at first I thought that it was the original drivers (the ones I got with the printer) so I donwloaded the drivers from the canon website, this did not resolve the problem. What I also tried and it worked for me was connecting the printer to the computer with it's original usb cable. I bought a couple of weekes ago a usb extension cable (about 5 m long). With this extension cable I can print but I can't scan any document, it just gives me the same error. Hope this works also for you.
Bye
PS: My printer is a Canon Pixma MP190
Posted on Mar 09, 2009
  • 7 Answers
SOURCE: Scanner won't communicate with computer
Try this,
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
Right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready toi use, re-connect the scanner USB lead.
Windows should re-install the drivers and tell you the scanner is ready to use................hopefully!
Posted on Mar 28, 2009
  • 92 Answers
SOURCE: Canon MP190 ScanGear error
Hi ....
Its always a pleasure to meet someone who has done the initial troubleshooting themself ... so looking at your comments, you have already tried the hardware and the drivers steps ... it shows that the issue is not with the device but something with your system ...
To me, it looks like the necessary files for the scan to work is missing from your system which is USBSCAN.SYS. This is a windows system file which is required by the scan drivers ...
Note: Make sure you are searching the hidden files too as this is a system file and could be hidden.
  1. Click 'Start', 'Search' and select 'For Files or Folders'.
  2. At 'Search Results' window, type usbscan.sys in 'Search for files or folders named' field.
  3. At 'Look in' drop-down menu, confirm your computer's hard drive is selected. In most cases, C: is the computer's hard drive.
  4. Click 'More advanced options' link.
  5. Confirm checkmarks appear beside 'Search system folders', 'Search hidden files and folders and 'Search folders'.
  6. Click 'Search' button.
  7. Once search has completed and if the file does not exist, consult the computer manufacturer.
    1. If the file exists and a message appears while installing the scan driver, direct the installer to the appropriate path. For example, C:\WINDOWS\system32\drivers.
    2. If the file exists and the message appears while scanning, click on the attachment to open Device Manager and check if the scanning device is listed as 'Other'. Then update the driver and direct the installer to the appropriate path. For example, C:\WINDOWS\system32\drivers (where C is your computer's hard drive letter).
  8. Close the 'Search Results' window.
I think this file is missing from the computer which is causing the problem. But there is another possibility as well. There are some services of the computer that need to be started to make sure that the device works file. The services are for everything like spooler services for printer so similarly there are WIA (Windows Image Acquisition) Service or Stimon(98 or ME) services for scanner depending upon your operating system.
It might be possible that these services are stoped or disabled. Follow the below steps to enable those servers:
How to start the Windows Imaging Acquisition (WIA) Service (Win XP)
  1. Click Start.
  2. Right-click My Computer and select Manage. This brings up the 'Computer Management' window seen below.
  3. Under 'Services and Applications' click Services. This will display a list of services in the right pane of the 'Computer Management' window. A portion of this window is seen below.
  4. Scroll through the list to locate and then double-click Windows Image Acquisition (WIA).
    This brings up the 'Windows Image Acquisition (WIA) Properties' window seen below.
  5. Be sure that 'Startup type:' is not set to Disabled. You can choose either Automatic or Manual.
  6. Once you have enabled the 'Startup type:', under 'Sevice status:' click the Start button to start the service.
How to start STIMON (Windows 98 & Me)
  • Click Start, then Run, and type "stimon.exe" and click OK.
Well according to me, this should resolve the problem. Just one more very important thing ....
Don't forget to vote if this helps :) ... Cheers ...
Posted on Aug 04, 2009
My canoscan fb620u shows device offline.
It your using a newer windows you probably need new software. Try Vue Scan it worked for me on Windows 7 64bit and I have the same scanner. With out dated software it wont recognize the scanner. Hope it helps
Dec 24, 2009 | Canon CanoScan FB620U Flatbed Scanner
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Code error -180
Check your USB cable.  I was getting the exact same error and I found out I was using an older USB 1.0 spec cable.  When I switched to a USB 2 cable it began working fine.
Todd
Oct 27, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
CanoScan LiDE 50 error code: 2,7,0
Has your scanner been working before?
If so, has anything changed since then such as new printers or other devices added to the computer, or upgraded to a new OS?
Which OS are you using?
When exactly does the error occur?
Does ScanGear open?
Are you able to preview?
Try connecting the USB cable to another port on the computer (directly to the computer...not through a HUB or any other device). Bypassing a hub, which would have to be a powered HUB, or other devices would rule out any issues with those devices.
Ultimately trying the scanner on another computer would rule out issues with the scanner as well.
May 09, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canoscan 4400F & Vista
It looks like the computers have a hard time communicating with the scanner it will be advisable to download all the current firmware available, her is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=13810#DownloadDetailAct
This should take care of the problems.
Oct 19, 2007 | Canon CanoScan 4200F Flatbed Scanner
Scanner won't communicate with my Mac
Uninstall the software with scanner unplug from your MAC. Install the software with the scanner disconnected, then connect it b4 the first use of the software.
Mar 28, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon PIXMA MX410 - multifunction  fax / copier / printer / scanner   color Logo
102 people viewed this question
old marine
old marine
