Candy error e15 dryer - Washing Machines
I got a new candy tumble dryer today and I put it on and E15 keeps showing what should I do
according to the my documents, this indicates the prom on the pcb is corrupted. Not sure how you can get it reprogrammed, replacing the pcb should fix it though.
Sep 26, 2016 | Candy Dryers
Does not heat error code e15 appears on the screen after a couple of minutes
If it is a gas dryer, check the thermal fuse, ignitor and solenoid coils. If it is an electric dryer, check the thermal fuse and heating element. In either case, clean your exhaust duct from front to back, where it attaches to the machine all the way until it exits the house.
May 02, 2016 | Dryers
Why do I have a E15 error code on my Model # 41784092500 KENMORE Residential Dryer
The micro-controller has been reset by the watchdog timer. I think you have a defective main control board.
Aug 26, 2015 | Kenmore Dryers
What is an E15 error code
The micro-controller has been reset by the watchdog timer--main control board is defective.
Aug 26, 2015 | Dryers
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine
well the error E15 means that the dryer thinks it's overloaded. Spin the tub by hand and make sure it's spins smoothly. If so then you have a bad motor unfortunately.
May 27, 2015 | Dryers
Electrolux dryer t 3650
Error code E15
When the error code is displayed this can be due to the user having overfilled the dryer.
Remove some of the clothes, close the door, and press the start button
Aug 19, 2013 | Dryers
Error code 15
What is the make and model number of your unit?
Feb 09, 2013 | Dryers
Hoptopint wd72 - E15 and wont take water in
Hi, - fixed this myself. Problem was a blocked pipe from front of drum to pressure switch. - The machine was fooled in to thinking it had water in when it hadnt! - hence the error 15. that was also why it would not fill. - im guessing the heater blew because it was on with no water to keep it cool!
Jan 09, 2010 | Hotpoint Ultima WD72 Front Load...
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
