Question about Utilitech Plumbing
Utilitech pump wont build pressure - Utilitech Plumbing
My pump does not hold pressure when the water is running cuts on at 20psi and the pressure keep droping.
Posted on Apr 23, 2014
  • Wayne Holden Aug 18, 2014
    Water supply from where? Pump primed? Where are you sending the water? Into a closed system or just out into the air? Must be a closed system to build pressure.
Pump shuts off at 20psi
you need a new pressure switch or adjust the old one for a higher limit ,
Dec 30, 2015 | Utilitech 1-HP Cast Iron Shallow Well Jet...
How do I figure out water pressure?
There should be a check on the suction side, and a gauge on the pressure side. Pressure comes from flow being slowed down or stopped. If the outlet is full open, no real pressure will be seen.
Aug 18, 2015 | Utilitech 1-1/2 HP Irrigation Pump UTP15P1
I have a 1/2 horsepower Utilitech pump hooked to a 36 gallon utilitech tank and need to know the cut in PSI
For normal house service cut-in is usually 20 psi, cut-out 40 psi. The pressure switch can usually be adjusted to 50 psi. For any more check the pump specs. Usually you can google that.
Aug 18, 2015 | Plumbing
Any suggestions when a newly installed utilitech pump won't turn off?
its sucking dry or your wiring is not right, or of course an airleak, or the prime is not good, did you fill the pump prime hole at the 3/4 plug on bottom.of pump, deep well pump do you mean submersible? if so and it is a deep well submersible there is a prime, its got to be an airleak in the line or the pressure tank is not pressured up to the specs, and the gauge
May 16, 2015 | Jet Plumbing
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Pump does not hold pressure
Sounds line a problem with the water source. A lot of information is needed to answer your question such as model number etc.
Apr 23, 2014 | Utilitech Plumbing
I have a utilitech jet pump can only set pressure to 20-40 would like to set to at least 30-50 but cannot .The pump is less than 6 months old .any ideas other than i bought the wrong brand
Sorry Richard,
Sounds like you are correct, you bought the wrong type of pump...if your looking for pressure/output you might consider purchasing a "sprinkler pump"...they will go past 70psi and more
Please take time to rate me
Bud
Mar 31, 2013 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Need manual for utilitech 43467
You might be able to obtain this directly from the supplier
Jan 15, 2013 | Utilitech 1/2 HP Convertible Jet Pump...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Plumbing Logo
991 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
