Question about Oregon Scientific WR108 Weather Radio
How to start my Toyota Avalon1996 after the battery was disconnected
Jump start highlander
Dealer ! Battery Disconnect or Replacement Problems Dead battery same as disconnected battery . Electronics go night - night !
Apr 16, 2016 | 2011 Toyota Highlander
I have a 2007 Toyota Highlander. We came back from a trip and the vehicle would not start. I went to jump it and the alarm went off. I disconnected the jumper cable and it stopped. When I reconnected...
Sounds like a bad battery. If the battery is OK than lock and unlock your Toyota with your fob. If it is still dead than take the better terminal cables off and touch the negative and positive cables together while both are disconnected and away from battery terminals. Should reset your anti theft system. Connect the cables back and try to start. again. If no crank likely bad battery. If battery is OK but no crank then it is the starter.
Apr 05, 2014 | 2007 Toyota Highlander Hybrid
Replaced battery but cut off after starting i my toyota camary 2003
Toyota vehicles can be finicky after the battery is disconnected and often tend to stall out. The problem will correct itself after a few start-run-shutdown cycles as the ECU has to relearn the engine trims.
Apr 01, 2014 | Toyota Camry Cars & Trucks
MR 2000 toyota would not start after sitting all winter.
the battery can be disconnected if you let it sit for more than a week. most common drain that i encounter is in the audio system. disconnect the negative battery cable and put a test light (wired light bulb) between battery post and cable end. if the light is on or even dim, start pulling fuses one at a time. if the light stays on, replace the fuse and move on. if the light goes out then you have found which circuit the draw is in.
Mar 31, 2014 | Toyota MR2 Cars & Trucks
2002 toyota sienna will not start, and does not seem to be batteray related
Disconnect the ground cable from the battery and check the cable going to the starter. (located on the starter) Make sure it is tight. Re-connect the cable to the battery ground.
Jan 31, 2018 | 2002 Toyota Sienna
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Dec 07, 2012 | 1992 Toyota 4Runner
Hi, have a toyota avalon, tried starting the car , it won't start, but then the starter engaged and won't turn off evenwithout the key, disconnected the battery and it stopped , when the batte
It sounds like you have a bad actuator. This is attached to the starter and has a solonoid that pushes the starter motor gears into the engine gear. If the solonoid is faulty this may happen. Also check alignment of the same.
Mar 18, 2012 | 1999 Toyota Avalon
Every time i go to start up my 1986 toyota pick up it just makes a clicking noise i have to push start it every time i want to go some where.
I would start by checking the connections at the battery and make sure they are clean and tight. If the connections are tight and clean, replace the starter.
On some models with automatic transmission, it may be necessary to disconnect the throttle rod.
  1. Disconnect the negative (-) battery cable at the battery, then disconnect the positive (+) battery cable at the starter.
  2. Disconnect the remaining electrical connections at the starter solenoid.
May 07, 2011 | 1986 Toyota Pickup 4WD
How do you change the alternator on a 2002 toyota avaoln xls
Disconnect the battery before starting the job! Your power cable from the alternator will be disconnected and could potentially ground out if your battery is not disconnected!
  1. REMOVE DRIVE BELT Loosen the pivot bolt, adjusting lock bolt and adjusting bolt, and remove the drive belt.
  1. REMOVE GENERATOR
    1. Disconnect the generator connector.
    2. Remove the nut, and disconnect the generator wire.
    3. Disconnect the wire harness from the clip, unplug.
    4. Remove the pivot bolt, plate washer, adjusting lock bolt and generator.
Please be sure to rate me if you find this information useful, thanks for using FixYa!
Sep 15, 2009 | 2002 Toyota Avalon
Disconnected battery cable but now it won't start?
there is two wires coming out of the positive cable and when you unhooked the cable the one that feeds your fuse panel may have came un plugged.
Aug 29, 2009 | 1996 Toyota Camry
Oregon Scientific WR108 Weather Radio Logo
24 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
