Question about GE Profile JS968 Electric Kitchen Range
Burner heat control on glass cooktop - GE Profile JS968 Electric Kitchen Range
4 Suggested Answers
appldoctom
  • 311 Answers
SOURCE: Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Posted on Jan 30, 2009
  • 37 Answers
SOURCE: large combination burner in glass top cooktop just
Yes it sounds as if you have control knob probs ..did it work b4 or is it a new cooker ?
Posted on Sep 06, 2009
SOURCE: Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Posted on Nov 18, 2009
My jenn-air 8430 cooktop left front burner cycles off-on in the HIGH position. What could be wrong?
I am assuming your cooktop is electric and your have a glass top, if so the burners sensor is bad and you might need to replace the burner. Again before buying anything and for me to help you, I would need a full model number. Some model have plate sensors and with no plate/pot burner cycles. Most of the time I find the sensor in the burner cant detect the heat and this ends up being a safety issue to protect the unit. All this information is based on the premise you have an electric cooktop and a glass surface.
I hope this helps.
Oct 16, 2013 | Jenn-Air Cooktops
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
One of my kitchenaid cooktop burners does not work
go to searsparts.com could be switch or burner or high temp fuse under glass
Jul 02, 2009 | KitchenAid Cooktops
Ge cooktop burner does not get heated but hot sensor light goeson
common for the glass top have a scratch,coz this a glass it normal for every time u use coz the metal for the pots & pans are sharp for the glass.tnx gerbee
Jan 26, 2009 | Cooktops
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Heating element will not come on
The best to test that is to remove the top and take the outer coil and use it on any of the other burners to see if it heats up, then youll know for sure is the element or the switch.
Eddie Rentas
Tupper Lake NY
May 14, 2008 | Jenn-Air JED8430 Electric Cooktop
Plastic melted on my glass cooktop
didi you try heating the burner slightly to soften the plastic a bit before trying to scrape off, cant see any reason why that wouldnt work, using a razor blade held flat will scrape just about anything off of the glass tops!
Apr 29, 2008 | Jenn-Air JED8430 Electric Cooktop
GE Profile JS968 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
