Question about Leupold GX-3 Digital Golf Rangefinder - 68015
Bottom part of the distance digital numbers do not light up
Need to know capacity for a Whirlpool washer with model number E113C68PXCAP4580
Its pretty easy to calculate. open the top and place a straight edge across the top of the washer, then measure the height in inches from the bottom of the tub to the bottom of the straightedge. Next measure the inner distance from one edge of the tub to the other and cut that number in half. For example: Say the height is 30 inches and the distance across is 28 inches (cut this number in half so use 14). The total cubic inch volume would be calculated like this:
V = 3.1416 x (14 x 14) x 30
3.1416 x 196 x 30
18472.61 cubic inches
Divide 18472.61 by 1728 giving a capacity (volume) of 10.69 cubic feet.
Mar 02, 2015 | Whirlpool Washing Machines
What causes "not compatible" error on display when dialing a long distance call
If you don't normally press "1" before dialing a 10 digit number, try doing it for the one that won't work. The first two digits in the area code you are trying to call may conflict with a feature code in the PBX. If that doesn't work, the number you are dialing may have been added to the PBX DNC (do not call) list and would need to be removed by the system administrator.
Feb 13, 2015 | Avaya Office Computers & Internet
Shadows on the bottom of close up photos
Use natural light or a ring flash. An onboard or mounted flash will alway produce a short distance shadow.
Dec 22, 2012 | Nikon D5000 Digital Camera
Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens: my rebel xti won't shoot a macro shot. There's pl...
There is a minimal focusing distance for all lenses. If you move closer to the subject than that distance then the camera won't focus on it. Check you lens manual for minimal focusing distance. It is 11 inches for Canon EF-S 18-55mm f/3.5-5.6 USM, for example.
May 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Pictures come out dark when we take at night or in a dark area...even when flash on
It might depend on what distance you expect the flash to travel in order to light the subject. How many times havbe you benn to outdoor cocerts and seen flashes going off Many of those pics are goin to be dark because the flash is unlikely to reach that distance to be effective and the only light available to the sensor is the ambient light.
You need to observe what settings the camera reports like F numbers and speed numbers 1/30 1/60 at 1/60 and below the flash is activated and the aperture might be F16 the rule of thumb is higher the number smaller the hole, which with flash this setting would be ok
if it goes to F4 5 or even 8 it may be too restictive and cause under exposure.
The ISO setting is also helpful to understand here to The ISO is like the old film speed number ASA 100 daylight film ASA 400 is more sensitive to low light so change your ISO (ASA) setting to a higher number and see if that helps you take a better picture
Cheers
Jul 30, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Faxing with a long distance code
after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
basically everytime you need the machine to wait for something to happen you need to hit pause
example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
1-234-567-8901 pause pause 12345 start
May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
Can't fax long distance now-
Do you have a DIGITAL phone service like Vonage?
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line..
Dec 17, 2008 | HP Officejet 5510 All-In-One Thermal...
Long distance text message will not send. error code 00107. I would like know what that code number means. bat999@videotron.ca
The caller has caller ID block placed on their acct/ this can interfere with sending sms messages to a phone that does not accept sms or voice calls from a line with caller id block/ I had cust resprond to a text with send new to area code plus 10 digit number/ success/ removed caller id block from service and had cust click *star 67 then area code plus 10 digit number/ if you choose to have your contacts entered with *82 area code plus 10 digit cell number you will get error 00107/ can not receive or respont to blocked calls particularly long distance/resolves iss/ I am a technical suport agent for sprint/ Happy Texting
Jun 06, 2008 | Cell Phones
Distance betweeen range top and microwave 60654
This is always covered in the owner's manual or installation manual. If you don't have yours, you can find one here.
In some cases, you can get it free if you see a "Manage My Home " link on the right side of the page after entering your model number.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
We're happy to help and we appreciate your thoughtful rating of our answer.
May 28, 2008 | Kenmore 60654 Microwave Oven
Lens focus and take
This is usually because there is not enough detail/light that far away that it can focus on. My big lens Nikon D70s sometimes does the same thing. I have to find something at the same distance but with a little more light, press my shutter button down and hold it down until I can shift over to the location of the picture and take the picture.
Hope this helps, if it does, choose FixYa! ThankYa!
Oct 23, 2007 | Canon PowerShot A410 Digital Camera
Leupold GX-3 Digital Golf Rangefinder - 68015 Logo
61 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
