Question about Casio Edifice Watches
Casio edifice metal watch strap end ( watch end fastening)
Where spring pin attaches to watch casing
4 Suggested Answers
indays
  • 111 Answers
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
Posted on Sep 02, 2008
SOURCE: Casio Wave CeptorModeule #2735
I drilled a coupleof very small holes in the plastic part of the case and also in the watch band where it attaches to the case. I mixed strong epoxy glue (two part) and held the two pieces together with clamps over night. That was 6 months ago and it is still holding. The holes helped squeeze the glue into the joint. Good Luck!
Joe
Posted on Nov 11, 2008
mcdevito75
  • 1970 Answers
SOURCE: Casio Fisherman (PAS400B) watch replacement clip for spring pins
mcdevito75 here, I'm surprised a jeweler couldn"t help. Here is Casio"s contact number, speak with them, TIP, get a spring bar 1/2 MM smaller and larger than what you measured. Contact Casio at 800-435-7732 9AM-----5 PM EST. hope this helps.
Posted on Aug 03, 2010
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
I have been given a casio wave ceptor wvq 570 as a present. Unfortunately the plastic strap keeps detaching itself, by pulling the strap pin out. The strap seems undamaged but has a lot of play round the...
If the pin keeps coming out, then it seems likely that it is bent.
This can happen if the watch is fastened very tightly and your hand bends back until it strains the pin.
I suggest that you go to a jeweler and have a new one fitted.
Jan 12, 2010 | Casio Wave Ceptor Watch WVA105
How to shortend the metal band
On most brands, there are pins that form hinges for the links of strap. You need to push them out. usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Sep 30, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
The strap is broken on casio watch
I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
I really like this watch, but it is a pity the bands are so weak.
Aug 14, 2009 | Casio Watches
How to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Feb 10, 2009 | Nixon Scout NIX0013 Wrist Watch
WV-57H Watch - how do you replace the strap? I have a new strap for this model and can't work out how to take the old one off and fit the replacement. Thanks
If you look at the watch from the side, you'll see that there's a two-part metal piece on the underside of the watch on each side.  The metal piece is a spring-loaded pin going through the strap which is holding on a larger metal piece.  You need to get another small pin (or an eyeglass screwdriver might work) so you can poke in the end of that spring loaded metal piece, which will allow you to slip off the larger metal bracer.  Then you can poke the spring-loaded pin entirely out of the strap and it will be freed entirely.
To help you visualize what you are doing, the spring-loaded pin operates similarly to a toilet-paper roll - you need to compress the pin so you can slip off the larger metal bit, then take out the pin, which will free the strap.
Oct 30, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Sep 01, 2008 | Casio Edifice EFA109-7AV Wrist Watch
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
How to shorten casio wva-430du-1aver watch strap
This watch looks as if it had the same watch strap as the Casio edifice.
Look at this link where you find a step by step solution with pictures:
How-to-shorten-a-metal-watchstrap
May 02, 2008 | Casio Watches
Watches Logo
26 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
