Question about Vacuums
Hose pipe for Euroclean Mitey vac ec300
I want Hose pipe for Euroclean Mitey vac ec300 model. Where can i get it? I stay in Dharwad, Karnataka
I want rubber washer to attach hose pipe of mitey euroclean ec300
Go to a used vacuum place they will have them there.
Jun 25, 2014 | Vacuums
How to check wether a motor is working
I remove the power wires going to the motor and wire a power cord directly to the motor to see if it will run.
Apr 18, 2014 | Vacuums
How to replace brushes
if its a up right vac turn in up side down probley 2 2 4 screws holw the bottom on the u can take the bottom off the brush should come out by pulling up on the brush just sets in slots jesus saves an loves you more than any body can in this world
Nov 05, 2013 | Euroclean 930 Canister Vacuum Cleaner Bags...
Switches will not turn off unit. model #cv450w
If the switches on the hose will not turn off the vac you have a short in the wiring of the vac pipe system or a defective relay on the circuit board. Plug the vac in again without the hose and disconnect the thin low voltage wiring were it plugs into or screws onto the vac.
If the vac continues to run once disconnected from the low voltage circuit you have a defective relay in the vac itself. Some are circuit board mounted , others freestanding. To avoid a service call you can take the tank off the wall and take it to a pro shop or remove the top hosing if you are confident and check out the relay for a replacement part.
If the vac stops your issue is in the house. Has any painting been done or any inlets removed lately.. check that area first for a short at the inlet. Go back to any and all inlets and remove them one at a time checking the mounting screws and backing plates for loose wiring which is touching either the metal inner wall plate in the wall or a common screw . Test the vac as you go.
If this does not help, you will need to examine the wiring in the house , running along the pipe. Again if anything has been disturbed recently, near the vac, or near any piping that would be your first suspect area.
Post back to advise.
Oct 18, 2009 | Broan-NuTone CV350 Central Vacuum
Hush - Insufficient suction
You need to approach this step by step. If you have insufficient suction at all locations you need to check as follows:
1. Hose, drop a coin through from the handle to the wall end, with the hose detached from the wall. If the coin goes through from one end to the other the hose should be clear. If the coin stops it will rattle inside where the obstruction is if you gently shake the hose you will feel it through the wall.Obstructions in hose or pie need to bee **** wards out of the hose or pipe.
2. Vac. Go to the vac itself and see if the onboard inlet has suction. If it does your problem is beyond the vac. If not your problem may be a leak, either a broken inlet, with a cracked or sagging door or jammed hinge, a clogged intake in the vac, or damage to the pipe within the house or a twisted gasket where the pail of the vac secures to the body, or an issue with the motor itself..
3. Take the hose, inlet to inlet and check all locations in the house. I mark a tissue with a number for each inlet and plug in the hose, one inlet at a time. If the tissue makes it all the way to the bucket from each location, that means the branch line for that location is clear. I work from the closest inlet away to the furthest checking for tissues one inlet a t a time. This will help pinpoint location of any blockage in the main line.
4. If you have had any renovations or painting done it is not uncommon to disturb the seal behind and inlet or pierce your piping with a nail or screw. Check for all these and post back to say waht you have found.
Sep 27, 2009 | Hoover S5636 Hush Central System Vacuum
I need a wiring schematics for my ezi-vac 2(euroclean) please.
Thanks for getting back to me,i solved the problem by asking a vac tech and he told me what to do ,it was easy.cheers gazza.
Feb 20, 2009 | Electrolux Vacuums
Won't work cleaning tools
There is a clog somewhere.
Most likely at any bends or where the hose enters the main body of the vac.
Make sure it's unplugged.
Romove the hose, stretch it out straight and see if you can see through it.
If there arer any hard piped bends try running a pipe cleaner through it to see where the blockage is.
Again, it's likely where the hose base meets the vac housing.
Needle nose pliers com in handy for pulling out string, hair, rig fibers pet fur etc.
Dec 06, 2008 | Hoover U5264-930 TurboPower Bagged Upright...
Central vacuum not sucking
Usually when there is no suction, and the main unit is running, then either the hose or somewhere in the piping there is a clog. If you move the hose to another location, is there suction? If not then the hose is clogged. You can unhook the pipe at the unit, flip the switch to manual, if it comes on and there is suction there, then there is a clog in the piping, If in the piping, tear up small strips of paper and mark them by number and insert one in each inlet, run the unit on manual to suck them up, and which ever numbered strip isn't there in the bucket, then that is the inlet that is clogged.
Nov 23, 2007 | M&S Systems AirVac AVP1200 Platinum Series...
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
