Question about DCS DRH-48N Patio Heater
Heater wont come on - DCS DRH-48N Patio Heater
Heater wont start;don't hear blower motor
there are a variety of causes for this. any one of the safety systems may have detected a fault and thus wont let the heater run. if there is no electricity, the heater wont run. if there is insufficient water flow, the heater wont run.
Jun 02, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Water leaking from the housing were the heater eliment is located
the heater core is bad in summer u just route your heater hose's togther where they go thru the fire-wall.put a splice between both hoseses so water wont go into heater-core in winter u need heater u must if u have to use vehicle slow-speed only remove rariator cap pressure then leak wont leak as fast u can use heater until fluid is all leaked out or u can just move heater slide to blue area then water wont be going to heater core it wont leak out as fast or replace heater core
Dec 27, 2011 | Cars & Trucks
Reddy heater wont fire
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 23, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 55 wont Fire
heatman101
Feb 03, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater stopped working
The heater core has gone out and will need to be replaced
Dec 07, 2008 | 2002 Mazda Millenia
Wont stay lit
go to this site www dot desatech dot com. Here you'll find parts to repair your heater. a propane heater uses a millivolt generator to sense the flame. along it's cappilary are two push on spde connectors. these connect to the high limit temperature sensor which is mounted on the flame backplate of your heater. to see if it is the high limit shutting down your heater, jumper across the two spade connectors. if the heater stays on, this is your problem. if the flame still goes out, then the millivolt generator is shot.
Nov 09, 2007 | Coleman 5075751 Utility Heater
Heating & Cooling Logo
27 people viewed this question
Top DCS Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a DCS Heating and Cooling Expert? Answer questions, earn points and help others
