Question about Bosch Hammering
11316 evs solid red light
Have replaced brushes and speed control
    Sergeant:
  • Bosch Expert
  • 206 Answers
Could be it is drawing too much amperage - that is what this control detects.
How long has it been since it was torn down & serviced - that is a possibility.
The other is more costly, it is possible you have a bad armature causing this as well. Remove the bottom cover where you replaced the brushes and examine the armature - look for burnt / raised segments or burnt windings.
Let me know what you find.
Posted on Mar 13, 2015
2 Suggested Answers
yasinabdirah
  • 22 Answers
SOURCE: Dewalt D25601. Red service Light flashing after 3 seconds.
Return o the store
Posted on Mar 05, 2014
Testimonial: "Thanks for the tip but I am the repair agent just waiting for Dewalt to get back to me as the engineer I spoke with had not dealt with breakers for a long time."
How to trouble shoot a brush warning light
What color light are you referring to? If it is one of the green lights that is normal for the up and down adjustments. If it is the red one that is another issue. If it is the red one, what does it do while it is on? Does it flash or is it on solid?
Jun 17, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
Solid red light
1 sliding contact of the 4 pieces thats on the electricfield (stator) of the motor is broken.
Apr 13, 2014 | Bosch Hammering
Honda rv generator.model#ev-6010/sn-ecb-1020622 when i hit the start button it will run but when i release button it dies the control board burnt up so i replaced it but still have same problem,the pilot...
one thing to try is if you can get into where the brushes are, remove them and take some emery cloth and put on the slip rings that the brushes ride on, they could be dirty with carbon and causeing it not to create power. that is a simple and cheapway of checking it.
Mar 02, 2011 | Honda Electrical Supplies
Fan will not turn under it's own power, but turns freely by hand. Light bulbs light up very dimly. Light sockets show 120volts when the switch is turned on if all light bulbs are removed, but if a...
You probably have a wire nut connection that is just barely connected. Perhaps it's a connection between stranded wire and solid wire where only one of the strands is making contact with the solid wire.
Jan 09, 2011 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Solid red light
Have about a 30 second window to replace batteries before all codes are lost and when you put in the new batteries it goes into programing mode. Re-enter codes and try it again. Have the same remote and it has happened to me before.
Mar 12, 2010 | DISH Network IR Remote Control
I have a BOSCH 4000 table saw which spins very slow. I opened the motor took out the field to examine. When I tried to reassemble it, I faced some problem. There are two wires from field, one connects to...
There is 4 wires from the field, 2 reds a white and a black. the reds have spade connectors on them, they go to the brush holders. The white goes to the white on the speed controler and the black goes to the black on the speed controller. There is one wire from the speed control that goes on to one of the brush leads, there is a small adapter that allows both wires to be connected. If the motor spins very slow then the field is faulty and needs replaced.
Hope this helps
Feb 11, 2010 | Bosch 4000 - 07 Electric Table Saws
What is EV on the menu
Hi cute_chic24,
EV is Exposure value refers to the amount of light for a given exposure. It is denoted as a single number. Its value is subsequently used to calculate the correct combination of shutter speed and aperture at a given ISO speed of the sensor.
Starting point is a shutter speed of 1 second at f1, which is denoted as EV 0. Further up the scale a single exposure of EV13 could be ISO 100, f8 - 1/125s, or f11 - 1/60s.
It doesn't make any difference which combination you choose, as all variations at the same EV will ensure a correct exposure. Remember though, you are always balancing camera or subject movement against depth of field. This is because a change in aperture will require a change in shutter speed for an equal amount of light to reach the sensor or CCD. If you set the shutter speed one stop slower and aperture one stop smaller, exposure doesn't change, but you increase depth of field slightly and the possibility of blur.
ERNZ
Feb 03, 2010 | Sony Cyber-Shot DSC-L1 Digital Camera
Schematic for EV Warrior Electric Bike
I have a PDF of the schematic i drew for my bike. it is posted on the Yahoo power-assist group. look in the files section.
http://tech.groups.yahoo.com/group/power-assist/files/EV-Warrior/
there is also a text file there that lists all of the wiring connectors and where each of the wires goes. as well as connection diagrams for the Curtis 1505 speed controller.
the charger circuit is very simple. the black and red wires from the charger port go straight to the batteries +24V and 0V terminals. the third white wire connects through a bullet connector to pin#7 (EPO wire) of the Curtis speed controller. this acts to turn off the motors while the batteries are being charged.
inside the charger male connector the pin for that 3rd white wire is shorted to ground. so when you plug the charger in the white wire is grounded thru the charger plug.
have fun. i really enjoyed my EV-Warriors while i could still ride them.
rick
Mar 12, 2009 | Electric Bicycle Motor, Bike,electric...
EV-1000B TV Remote
Codes for all Casio TVs are available here http://casio.jp However, they are all in Japanese, so you'll have to run it through Google's translate service.. Hope that helps..
Jan 27, 2008 | Casio EV-1000 10.4 in. LCD Television
Hammering Logo
811 people viewed this question
Top Bosch Hammering Experts
John Trevino
Mike
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
