Question about Rowenta Autosteam 1600W Self Clean Steam Iron DZ1700
How to use the self clean - Rowenta Autosteam 1600W Self Clean Steam Iron DZ1700
I've lost my instructions for how to clean my self cleaning iron, need step by step instructions.
Heat to highest Heat level , then press self clean button on the iron
Mar 17, 2015 | Irons
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Frigidaire Gas Self Cleaning Oven door open in lock position
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
How do i use the self clean
please refer to the owner manual for the proper use the self clean. download the manual from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Jul 22, 2012 | Breville 2400w Steam Iron Stainless Steel...
How do I self clean? I don't have a manual?
This is a guess?
I believe it self cleans while you are ironing!.
May 29, 2011 | Rowenta Powerglide DM253 Iron
Lost my self cleaning instructions, please help
You can download the complete instruction manual in PDF format by clicking this link.
The detailed steps for self-cleaning procedure is given on page 6 of this manual.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 15, 2010 | Rowenta Effective DX1900 Iron with Auto...
How to use the self clean feature on a tefal steam iron
I cleaned mine with alcohol and clean terry cloth. Took some work but it eventually got clean.
Dec 24, 2008 | Irons
Rowenta iron
vinegar and water then put the iron on self clean..
then just plain water x2 on self clean.
Mar 21, 2008 | Irons
Rowenta Autosteam 1600W Self Clean Steam Iron DZ1700 Logo
51 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
