Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
My freezer also just jumped to 17° and won't go down to 0.
My GE refrigerator freezer --It has worked fine until now. This afternoon the freezer temp jumped from 0 to 17, and it won't go down. The area around the door seems quite warm.
  • GE Master
  • 4,655 Answers
We need to check the evaporator fan and the condenser fan. The heat in the door frame is normal when the refrigerator runs normally. But when a control board or fan fails the heat may increase because they are heat strips behind the door or condenser lines placed there to prevent moisture around door seals. We also will need to unplug and have a look at the mother board on back behind a panel. Many times the board will show burn marks on the back or front. When you are ready let me know, Thanks, Sea Breeze
Posted on Jun 18, 2009
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PDS22SBRR bottom freezer not cooling. I adjusted the controls to cool and overnight it goes to 0 but if I open the freezer just once the temp jumps to 12 or 14 degrees. Please advise, thanks!
This sounds like a pretty normal condition. How long after you open the freezer does it take to recover (i.e. go back down to 0 degrees)?
The freezing temperature of water is +32 degrees Farenheit, so as long as your food is staying frozen, I wouldn't worry so much about it.
Is this a new (different) condition or are you just now noticing it?
Good luck. Hope this helps.
Sep 12, 2009 | GE Profile PDS22SBRR Stainless Steel...
Refridgerator side of my side by side is Hot
Glad I was able to be of assistance. Did not post as a solution previously as I needed to ask a few questions first.
Jul 29, 2009 | Danby (DAR604BLS) Refrigerator
Freezer works refrigerator doesn't
Try finding the defrost timer and slowly click by click turn it just until the compressor stops. let it finish the defrost cycle. Let it run for about 3 hours then do it again. Sometimes if the frost builds up too much the defrost system can't handle it. If you can't find the timer, take out the food, unplug it and leave the doors open for at least 24 hours. Then plug it back in. It can take up to 10 hours to cool down completely. Use a thermometer. you should be around 38 degrees in the fridge and between 0 and 10 degrees in the freezer.
Jul 04, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
Refrigerators Logo
221 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
