Question about Stihl Ts 410 420 Cut Off Saw Decompression Grommet
Ts 410 won't start - Stihl Ts 410 420 Cut Off Saw Decompression Grommet
  • 45 Answers
Check for spark, check for fuel, if you have both poss pot and piston
Posted on Nov 29, 2014
Could someone tell me the difference between a Stihl TS410 and a TS420?
maybe here. http://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-TS-410-420-Owners-Instruction-Manual.pdf
Mar 17, 2016 | Stihl Saws
I have a stihl ts 410 that runs but after use it floods with fuel and then won't start till I have vented it
Sounds like a faulty fuel tank vent, creating a vacuum lock. Replace the vent
Feb 16, 2016 | Stihl Saws
2 year old TS410 no power recently, was serviced , correct mix but dies when pressure comes on ,blade stops, starts fine and runs idle fine-tom
Hi Thomas its probably had its high/low screws reset and whilst it runs fine on the bench under load its running weak try unscrewing the high screw out a half a turn
Aug 16, 2013 | Stihl Ts 410 420 Cut Off Saw...
Stihl ts 400 has stopped working and sounds rough when pulling the cord
Sounds bad, the only answer here is to pull the cylinder off and check the condition of the internals, if there is a lot of dust behind the filter and into the back of the carb the engine is going to be in need of rebuild.
Mar 25, 2013 | Stihl Ts 410 420 Cut Off Saw...
How do i remove the clutch from a ts 410
It should be threaded to the crank. On the end of the clutch it is hex shaped. I always used a metric socket and impact to pop them off. I am pretty sure they are left hand thread and there should be marked with "off" and an arrow showing this.
Jul 02, 2012 | Stihl Ts 410 420 Cut Off Saw...
I have a stihl ts-410 cut off saw. it will start and idle but when i squeeze the throttle it dies. how do i adjust the carb?
if this machine ran ok before this problem,and no one has adjusted the carb,then i would check the crank seals.i have just had this problem.and it was the seal on the puller side,though i replaced both whilst i was at it.hope this helps my freind.
Nov 28, 2011 | Stihl Saws
Hi,my stihl ts 410 saw cuts out after about 10 minutes work,it restarts soon after then cuts out after about 10 minutes again? any ideas,thanks dave
Sounds like an overheating problem.
Are you working in a well-ventilated area or in direct sunlight?
Check, if you can, the temperature of the motor case.
You might have to take a break more often.
This hot summer has stressed a lot of motors and electronics.
When it shuts off you know it is trying to save itself from burnout.
Aug 29, 2011 | Stihl Ts 410 420 Cut Off Saw...
Stihl 410 wont start put new spark plug but no spark
Try a new coil.Hope this helps and Thank You for asking!!!
Jul 19, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
Stihl Ts 410 420  Cut Off Saw Decompression Grommet Logo
478 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
