Question about LG LSC183VMA Split System Air Conditioner
Error code E3 kolin inverter model KSM-15CBI
THE UNIT RUN IN FEW SECOND THEN **** DOWN ERROR CODE E3 SHOW
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: system 3 in-door with system
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Posted on Jan 01, 2011
My dishwasher gives an E3 error
The E3 error code is not a defined error for this dishwasher. If you are sure it is E3 then best option is to give the controller a reset. This is done by
Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
Press OFF at this stage. Do not attempt to run the inspection as this could damage the dishwasher unless you are familiar with the what each mode does.
If the Error E3 keeps coming back then call the Samsung technician.
Apr 15, 2014 | Samsung DMR57LF Builtin Dishwasher
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
My cannon printer shows Error Code 3. What does it mean please? Thank you.
Hello Gm,
Please check printer is turned on by pressing the "On/Off" button, you will notice the display prompt you for E3 (error 3). Press and hold the "On/Off" button for one second. The display will go blank and begin resetting the malfunction. Wait 10 to 15 seconds and restore power to the unit by pressing the "On/Off" button once more. Allow the unit to complete its cycling process and the error code should be gone. If the code persists, your printer will need professional maintenance.
May 19, 2011 | Office Equipment & Supplies
Error 3 showing
Follow the below mentioned steps to resolve the issue : 1. Ensure the Pixma is turned on by pressing the "On/Off" button, you will notice the display prompt you for E3 (error 3).
2. Press and hold the "On/Off" button for one second. The display will now go blank and begin resetting the malfunction.
3. Wait 10 to 15 seconds and restore power to the unit by pressing the "On/Off" button once more.
4. Allow the unit to complete its cycling process and the error code should be gone. If the code persists, your printer will need professional maintenance.
Apr 22, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
E3 code error.
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Sep 20, 2009 | Maytag MAH2400A Front Load Washer
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
Sep 06, 2008 | LG 24 in. LD-12BW5 Free-standing...
E3 is flashing on display panel
Calling two service centers, they both indicated that the main circuit board needed replacing. This would need shipping the unit!!, part and then labor. I figured over $120 - not reasonable. I then took the unit apart and followed the wires from the compressor to the back of the unit. This is where the moisture sensor was located - upper left. You'll see this when you take the filter off. Anyway, I cleaned the face of this part with a old toothbrush, used some compressed air to remove any dust. I then followed the wires with the black sleeve that went to what I think is a temperature sensor - also on the left. The wires go to a sensor that is pushed into a copper tube that is part of the cooling tubing. Gently pull this out, wipe it down and re-install. I then plugged the unit in, set the humidity level and it now works. I just put the unit back together and the compressor is turning on and collecting moisture! I will run it a few days and keep checking on it to make sure it doesn't go into the 'E3' Mode. By the way, the repair shops I called really didn't have a clue what the E3 code was. Dennis
Jun 15, 2006 | DeLonghi DDE40E Dehumidifier
LG LSC183VMA Split System Air Conditioner Logo
363 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
