Question about Moyer Diebel 24 in. 501HT Built-in Dishwasher
Water level What should the correct and/or optimum water level be in the tub of this dishwasher for proper operation? There is water in the bottom of the dishwasher after the cycle completes. 1)checked the hose, it is not kinked 2) not hooked up to a waste disposal. What else could it be??
  • 6 more comments
  • Anonymous Nov 03, 2008
    I have the same situation with water in the dishwasher after the cycle completes. ..I think this is a problem as the other two dishwashers we have had at other homes have always been empty upon completion of the cycle.
  • jimkimsul Dec 26, 2008
    After the complete wash and drying cycle there is about 3 inches of water left in the dishwasher, what is wrong??
  • gbee1 Jan 07, 2009
    I just started having that problem with about 2-3 inches of water left in bottom and some actually overflows onto floor when door is opened after cycle complete. Any ideas what to check? Drain is clear.
  • sammunt Jan 21, 2009
    There is a lot of water at bottom of the Dishwasher and it's covering the top of the drain cover. Is this normal because we never notice before and we don't hear the water going down the drain any more.
  • Anonymous Feb 25, 2009
    At the end of the wash cycle, a lot of water remains in the bottom of the dishwasher and it leaks out through the door... This is an intermittant problem...
  • y678 Feb 25, 2009
    Exact same problem, 2-3 inches of water at the end of every cycle - I had a technician in to check the pump and it was fine, and the lines are unclogged.
  • Anonymous Mar 09, 2009
    Same issue water on the bottom of dishwasher
  • guesting May 19, 2009
    Dish washer occasionally over flows. Have checkd the filters and they appear to be clean. Is it the level switch or a water pressure problem or plugged filters or food cutter? Model is the Kitchenaid KUDG25. ~7 years old.
  • 27 Answers
Some water in the tub after the cycle is complete is normal. most dishwashers are time filled with a float switch as a safety device. the actual level depends on the fill time and the water pressure. what exactly is the d/w doing (or not doing) to make you think there is a problem?
Posted on Nov 01, 2007
    Scholar:
  • 86 Answers
Hello Purtf
Hope you have sort out your water level problem , if you still want an answer please email me at dickson@lau.com and I'll try to help you in anyway I can. God Bless have a nice day Dickson
Posted on Jul 02, 2009
Dishwasher stops working a few minutes after being started
Make sure the water is turned on to the unit first--next, is there water entering the tub? Check the float switch--the round, plastic, "flying saucer" shaped object at the bottom of the tub. Gently lift up on it and carefully listen for a very soft "click" sound. That is the tiny switch underneath working. If something gets trapped under the float switch, the washer won't fill with water. Next, if water is indeed in the tub, did you hear the motor pump running? If it runs and then stops, there might be a problem with the control board--check to see if the drain pump works properly--cancel the cycle and listen for the drain pump turning on and draining out all the water. On almost all dishwashers, at the start of a cycle, the drain pump will turn on briefly to pump out any standing water left in the motor base(you can't see the water but it's there) so it doesn't get sprayed onto your dishes. Then, fresh, hot water enters the tub, when the water level reaches the proper level, the float switch rises, tells the computer enough water is present, then starts the main pump. If the water is not being drained out, try to listen for the drain motor humming. If it is running but not draining, it is probably jammed with food or other debris and must be cleared. If the water is turned on but no water is entering the tub, check the inlet water valve underneath the washer--the water line is connected directly to it. It is electrical and operates on 120v. You will need to carefully disconnect the connector from the valve, activate a cycle, and using a voltage meter, check to see if 120 volts is present. If it is there and no water is entering, most likely the valve is bad. If there is no voltage at the valve, either a wire is broken or the main board is defective.
Jul 30, 2015 | KitchenAid Kitchen Aid Superba Series...
When we turn on the dishwasher there is no water entering the appliance..then it cycles to drain the water and I reset it so the pump doesnt burnout...what could this possibly be and is there some...
hi Mapletonmob.
this is all i could find out.
A dishwasher that will not fill with water can be frustrating and repairing it through a serviceman can be expensive. Even for someone who may not consider themselves handy, repairing a dishwasher is not a difficult process. Below we've provided you with a list of the most common parts that fix a dishwasher will not fill with water. Use this information to help troubleshoot which part is broken
The water inlet valve is used to fill the dishwasher with the proper amount of hot water and is controlled by the timer or electronic control. The valve will be located behind the lower access panel and will have two wires attached to it, an outlet hose to the tub and a hot water inlet from the household supply. If your dishwasher does not fill then you should first check the inlet supply to verify that you have enough water pressure and that you have power going to the valve during the fill portion of the cycle. If these conditions are met then the valve is defective and should be replaced. If you do not have power to the valve then you should look at the float switch, the timer or electronic control or the door switches as a possible problem. All of the electrical checks can be made with a multi-meter.
A malfunctioning float could cause the dishwasher to not fill with water. The float is located at the bottom of the dishwasher tub and acts as a safety device that prevents the dishwasher from over filling with water. The float rises with the water level in the dishwasher and when the proper level is reached, the float will trigger the float switch to turn off the water inlet valve. Check that there is no debris or foreign objects that might restrict the vertical movement of the float and that it engages the float switch located beneath the tub.
The float switch sits below the float, beneath the dishwasher tub. When the float switch is triggered by the float, power to the water inlet valve is interrupted and it stops the flow of water into the dishwasher. Verify that the mechanical action of the float to the switch is operating properly and that the wire connections are secure. To check that the float switch is working properly, remove the wires and test for continuity with a multi-meter.
The door switch is a simple on/off mechanism that prohibits the dishwasher from operating when the door is open. If the door switch or switches are malfunctioning the dishwasher will not fill with water. This door switch mechanism is typically located behind the door panel at the top of the door. To verify the operation of the switches you will need to separate the inner door from the outer door and then remove the wires from the switches and check for continuity with a multi-meter.
We've identified the most common parts that can cause the dishwasher to not fill with water, but there are other parts that could be at fault. If you are unable to fix your dishwasher with the information above,
if none of the above work you might have to call someone out to have a look at it.
Nov 29, 2017 | Maytag Dishwasher
Fdb1050rec1 frigidaire dishwasher door leak
I think you most likely have a basin Float water level sensor that is no working correctly, the door seal is not water proof, if the water level gets over the lip of the basin it will leak on the floor.
May 01, 2017 | Frigidaire Dishwashers
F1 bottom drawer locked
F1 means the flood switch has been activated. here is a trouble shooting flow chart.
1. did a flood occure? yes. q-2 or no q-12
2. is the lid sealing on the tub correctly? yes Q-3 no=Answer
3. Is there a high water level in the tub. Yes-q4 no q-6
4. is the water valve leaking? yes=Answer no-Q 5
5. Is the dish drawer priming correctly? yes q-11 no q-6
6. Is the spray arm split. yes=answer, no q-7
7. is the spray arm running freely. yes q-8 no q=answer
8. is the water leaking from a split inlet or drain hose? yes = answer, no q9
9. is the water leaking around the heater plate or o rings. yes=answer, no q10
10. carroy out more testing to locate the source of the leak.
11. drain hose may have been blocked or partially blocked.
12. is there water or condensation around the chassis flood switch pcb.
13. if power fails to the bottom tub, it will cause the top tub to f1
Jan 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Blanco dishwasher overflows at end of cycle
There is a float connected to a switch that controls water level. It is usually round and will move freely up and down by hand. But your problem might be a levelling related one. The dishwasher must be level to operate correctly. Use a torpedo level in the tank base to check front to back level and side to side level. Adjust the front legs to level the unit.
Jul 30, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Kenmore dishwasher is not washing properly and leaving dirty water in the bottom when it is finished, Can i fix it?
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jun 02, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Water level/dirty dishes and traps
sounds like the drain pump is not doing its job to recycle the water and allow for replemish of fresh water for the rest of the cycles,try looking closely at pump out system and monitior how fast it disposes of water hope this helps
May 27, 2009 | Kenmore 15121 Built-in Dishwasher
Water level too high in tub causing water to leak out front
Sounds like the drain hose is disconnected. Check to make sure that the tube is not blocked and is connected properly. If the checks out then you should check your water sensor meter and make sure tht it is stoppingthe system at the correct points.
Apr 08, 2009 | Dishwashers
I'm just wondering how much water should be in the dishwasher for proper cleaning? Should it cover the heating element?
Water level can depend on the model and manufacturer. The water will fill to the level of the float switch. This is a plastic looking thing near the front of the dishwasher along the tub bottom that looks like and upside down cup. The water level reaches a point to where the float lifts and activates a cut-off switch which will stop the water from filling, followed by the wash cycle beginning. Now, depending on where the heating element is located, the water level is usually just touching the element and not necessarilty covering it. Does this help you? If you still have questions, let me know.
Jan 01, 2009 | Kenmore 16372 / 16374 / 16379 Built-in...
Water level
I'm not sure I understand your question. There isn't supposed to be any water left in the tub after operation. If there's any water left it might indicate that the dishwasher does not drain properly. If that's the case - - If the unit is hooked up to a food waste disposer, make sure the disposer is empty. - Check to see if the knockout plug has been removed from inside the food waste disposer inlet. - Check to see if drain hose is kinked. - Make sure cycle is complete, not in a pause.
Mar 22, 2006 | Frigidaire 25 in. FDP750RC Free-standing...
Moyer Diebel 24 in. 501HT Built-in Dishwasher Logo
869 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
