Question about Thermador KBUDT4270A Side by Side Refrigerator
Thermador fridge says locked - Thermador KBUDT4270A Side by Side Refrigerator
I have double wall unit Thermador oven. After self cleaning, the door can not open. Or may be I hit the panel lock , so the door is lock. How to unlock?
Hello April,
If any OVEN FUNTION is being used...
The controls cannot be LOCKED off...
So no... REQUIRES PUSHING 2 buttons & holding
for four (4) seconds... (not likely to be accidental)
The steps to Lock & Unlock are the same...
(see reference page (click here)
Thermador SCD302 Care And Use Manual Child Lockout
Touch and hold the COOK TIME pad and
the STOP TIME pad simultaneously for 4
seconds.
Likewise SELF CLEANING is described in great detail.
(double click this URL)...
Thermador SCD302 Care And Use Manual Page 29
ELSE...
Please contact THEM if you have questions or comments.
Phone: 1-800-735-4328 or reach THEM through their
website at www.thermador.com
Hope this helps
Carnac the Magnificent
Dec 20, 2017 | Thermador Ovens
Power module replaced on my Thermador T241F70NSP/03 built-in-freezer which fixed inoperative display. Now I get a click sound but the compressor is not starting. How do you check compressor?
You bought a Fancy fridge, now pay a Fancy technician to fix it...
Trying to own Thermador appliances on a budget is not possible nor is it intelligent.
Sep 03, 2016 | Thermador Freezers
E11 thermador
Thermador built in Fridge-freezer (T36IB..) experienced a 3 day power outage in area thanks to Hurricane Irma. During that time it was cleaned out and freezer was dumped and when power came back on it was working, and in a few minutes it started it's beeping noise and error code E 11. Freezer and refrigerator are both working, I have tried turning it on and off at the button and then once at the breaker. I have tried holding down the alarm button 3-5 seconds; I have a hunch it may be the freezer/ice maker trying to "start up". Any ideas what to try next?
Dec 19, 2013 | Thermador Freedom® T18IF70NSP
The fridge has stopped working but the freezer is working fine.
Have the settings been adjusted for the refrigerator? There should be either some knobs or a touch panel inside the fridge.
Hopefully it is an easy fix!
Sep 07, 2011 | Thermador T36IT71FNS (196 cu ft) Bottom...
MY displat shows a Child Lock problem. I find nothing in the manual about chikld lock. How do I unlock?
Manuals for some Thermador Microwaves are available here: http://www.thermador.com/trade/specifications-guides . Scroll down to Microwaves and select your model. Then press the link for Product Manuals and then choose the manual.
On the
MBES and MBESLFTD, the child lock feature is unlocked by pressing Settings 5 2 (touch each pad/number once).
If you have a different Thermador microwave, I'll check my stack of manuals for the specifics. (On a few other brands, the child lock can be toggled by pressing and holding the Start key. One of my other microwaves has a small padlock on the key to indicate the correct key. With that toggle, press and hold the key for 3-4 seconds or longer.)
I hope this helps.
Feb 19, 2011 | Thermador Microwave Ovens
Hi, I bought a Thermador built-in refrigerator T30IR7ONSP in November 2008 and I have had a custom-made front cupboard installed. Since a few weeks, there is water coming from the bottom of the fridge...
Could be the water line to and inside the refrigerator is leaking. Unfortunately, most likely the repair person will need total access to the unit to find where the problem is.
Mar 18, 2017 | Thermador FREEDOM T30IR70 Stainless Steel...
Thermador Freedom T361T70NNP - French Doors - Condensation
I have the same problem, and thermador stated there was a recall on the hinges. They are replacing the hinges to a newer stronger hinge that will pull the refrigerator doors in tighter. It took three different service companies to find the answer to this problem because I was told Thermador does not want anyone to know about this issue they have.
Jun 29, 2009 | Thermador FREEDOM® COLLECTION T30IR70NSP
Thermador KBUDT4270A Side by Side Refrigerator Logo
11 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
