Question about Kitchen Ranges
Kitchenaid Superba gas range error code F1 E8
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
  • 1214 Answers
SOURCE: KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Posted on Jan 29, 2009
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
Posted on Aug 28, 2009
localwonder
  • 6784 Answers
SOURCE: whirlpool gas range m#SF114pxsq1 diplays an F1 error code
HI. This is a basic Electronic Range Control Board failure code. I would advise to try a hard reset. This may correct the fault, if the damage is not severe. Simply unplug, or shutdown the appropriate circuit breaker for five minutes. After the five minutes have passed, kindly re-introduce power to the unit once more. Try to preform a baking cycle. if the code continues to illuminate during the attempt to operate the range, simply replace the main electronic control board(ERC or Clock).
Posted on Nov 16, 2009
jyackle5
  • 8197 Answers
SOURCE: KitchenAid Superba Gas Range error code F3 E0 when
The F3 E0 means
Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse Good luck
Posted on Nov 27, 2010
Error code F1 F3 F6
KitchenAid Fault Codes - AppliancePartsPros.com
www.appliancepartspros.com/repair-help/kitchenaid-fault-codes.html
Jump to Kitchen Aid Range / Stove / Oven Fault Codes - Failure Code, Fault CodeDescription, Solution ... F1 - E6, Latch signal mismatch error ... F3 - E0, Oventemperature ... electronic control will display F6 ...
Jan 27, 2016 | Kitchen Ranges
Fault code F1:E2
F1-E2 - UL A/D Error(s) - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks
Oct 10, 2011 | KitchenAid KGST307 Gas Kitchen Range
F1:E2 ERROR CODE
This error code is a problem with an integrated circuit on you electronic range control.
Mar 30, 2011 | KitchenAid KGRT607HBS Gas Kitchen Range
KitchenAid Superba Gas Range error code F3 E0 when trying to strat the range
The F3 E0 means
Nov 27, 2010 | KitchenAid Kitchen Ranges
Kitchen aid superba oven is getting a error code of: F3-E0 the temperature won't go over 250
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 29, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
F1 e1 error code...oven has previously cut off
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 09, 2009 | KitchenAid KGSA906P Gas Kitchen Range
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Jan 15, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Ranges Logo
114 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
