Question about LG 37LC7D 37 in. LCD HDTV
HDTV and connecting speakers...
Is it absolutely necessary to use an amp or receiver when connecting speakers to my TV. A Radio Shack person said that they can connect directly without one???????
  • Devon Sacco
    Devon Sacco May 11, 2010
    What is the model number of your TV?
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
If your TV has audio output jacks on the back, then you don't need an amp or receiver. These jacks use traditional composite cables that are red and white in color. I'm talking about the same kind you use with a dvd player.
F.Y.I. A lot of TVs don't have composite audio outputs, but they will have what's called an optical audio output. That type has to be used with an amp or receiver because you can't plug that type of line into any speaker.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
How to connect HDTV antenna to an old Sony Am Fm Radio Tv Receiver, Model Tv-413?
yes there is an coax to ant adapter. Check walmart or Radio Shack if they are still in business.
Apr 06, 2015 | Sony Am Fm Radio Tv Receiver, Model...
How do I conect external radio/speakers to my lg 42lh40-ua
There are many options here. Most HDTVs today have analog audio and digital audio output jacks. You can use RCA audio cables or a 3.5mm connector, whichever your HDTV has to connect the analog stereo output of the TV to any number of devices such as a stereo/amp which has speakers attached. You could also connect an FM transmitter to the TV and send the audio wirelessly to a nearby FM radio, boombox, portable etc. Most HDTVs today have a digital audio output, typically optical, which uses a digital audio cable ($15) to connect to a surround sound receiver. You can also connect the stereo analog output jack on the TV to a 2.4GHz transmitter and receiver speaker combo to get wireless audio outside, in a swimming pool and so forth, all around the house using wireless speakers. These setups usually cost around $150 or so. Look for the jack on the TV labeled AUDIO OUT and see if it is the white and red 2 jack ports or the smaller 3.5mm single jack port. Adapter cables are available at Radio Shack for around $10 should you need them. So you see the options are almost endless.
Aug 17, 2010 | LG 42LH40 LCD TV
Kenwood Receiver VR 806 turning off
Sounds like the music amplifier is different to the tuner audio amp. The music amplifier is now looking at an unbalanced impedance which is less than it should be. Therefore the output chip of the music amp has more current through it than it wants so it gets hot and shuts down.Put a four ohm wirewound resistor ( from Radio Shack ) in series with each surround speaker to reduce the current flow through the amplifier output.
Apr 09, 2010 | Kenwood VR-806 Receiver
Hdmi connection from receiver to hdtv, with set top cable box and no sound from speakers
Check your HDMI sound settings. You can choose it HDMI sound should go to receiver+speakers or to TV.
It is in menu: Setup / Func. setup / HDMI Audio. Options are: Amp / TV / Amp+TV.
Dec 25, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
External speaker hook-up possibility
Yes, its absolutely possible. You can connect external speakers from analog output of TV. Even you can use AV receivers available in the market which can be used to amplify OR process the tv sound with latest digital processing techniques, it would be very much pleasant than the sound from tv.
--Sandy
May 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $21.99...you might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Nov 17, 2008 | Bose 901 VI Main / Stereo Speaker
Trying to hook up 901's with a AVR2802 Dennon amp
Nov 16, 2008 | Bose 901 VI Main / Stereo Speaker
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
Connect speaker selector to reciever
Dear fellow stereo fans:
First, you connect the wires which would go to your speakers in th respective speaker a or speaker b out. Second, connect one pair of wires from the receiver to the speaker selector. I hope this is helpful.
Nov 18, 2007 | Harman Kardon AVR 235 Receiver
LG 37LC7D 37 in. LCD HDTV Logo
216 people viewed this question
