Question about Apple safari
Font was showing differently in safari - Apple safari
  • 555 Answers
Try to check the font type set on your safari browser. Go to browser Options and if you want to change the fon't used in your browser then you can change it within your Browser Options.
Posted on Jun 18, 2009
    Sergeant:
  • 321 Answers
Ur fonts is missing. load that font which is missing
2 Suggested Answers
pbenke
  • 88 Answers
SOURCE: safari table width problem
Safari fully passed Acid3 test (http://webkit.org/blog/280/full-pass-of-acid-3/) so, how Safari showed width of your table is how you designed table width...
Posted on Jun 24, 2009
How to decrease font size
Hold the command key, and then press the minus button, that should decrease the font
Mar 14, 2015 | Computers & Internet
I need my default zoom to be 175% on safari. How do i do it?
Open the Safari preferences and then select the advanced tab. Change the section labeled "Never use font size smaller than" next to the accessiblitly section.
Once you set your desired size, fonts should always appear larger.
Hope that helps!
Sep 16, 2013 | Apple safari
Word document
Choose a font and type. Try highlighting a word, sentence, paragraph and then select different types of fonts. This will only modify select items. You can also view fonts in c:\windows\fonts
Aug 28, 2012 | Microsoft Office 2007 Basic for PC
Hi....i want to know the different types of fonts how it looks like in EPSON LQ300+II printer??????? and i want to know how i can change the font without entering the default settings?????? thanq
Press the Font button. Font lights should come on or off to show the current selection. Press it repeatedly to cycle through all of the available selections.
Here's the table, 1 means on and 2 means off and 3 means flashing
Font ' Font lights Roman : 1 1 Sans Serif : 0 1 Courier : 1 0 Prestige : 3 1 Script : 3 2 Draft : 1 3 Draft condensed : 2 2
Dec 10, 2010 | Epson LQ 300+ Matrix Printer
Screen shows wrong URL Safari won't load.
By the way you are stating your issue, I am not sure if you are referring to Safari loading to an incorrect URL and that it is not launching. So to make sure I cover all bases I will provide advice for both.
If Safari is loading to a URL when you first launch it, assuming you are referring to the URL of the Home page you need to see, all you have to do there is launch Safari, click on the Safari name in the menu, select Preferences.
* Then under General> "Home page:", make sure the home URL is set to the web address you want to see as your home page.
If Safari is not launching on the other hand, here is what you need to do in order to resolve that issue:
font.f1 {font: 12.0px Helvetica} • From your desktop,
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Home from the
drop-down menu. This will take you to your Home folder.
• Locate and open the Library folder
• Within Library folder look for the Preferences folder and open it.
• Locate and remove to the Trash, these files:
com.apple.Safari.com
com.apple.Safari.RSS.com.
Now click the back button in the Finder window to go back to the Library view.
* Locate and remove to the Trash, the folder entitled "Caches"
* Once you have done that, close all windows and other applications, click on the Apple menu icon and select from the drop down menu Logout<username>.
This will take you to the main login window
* simply log back in to the same user account.
Don't attempt to launch Safari, just yet. Instead run this last procedure to repair file/folder permission on your Mac OS X volume (including Safari)
font.f1 {font: 13.0px Myriad Pro} -RUN DISK UTILITY FIRST-
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed
this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utilities run this repair permissions until completion
- This is not often a necessary step, but in the many of the hands-on software and Mac OS X troubleshooting
* Once Disk Utility is complete and there are no errors in red in the completion summary (if there are errors listed in red, re-run DU to see if those error will clear- if they don't reply back to this post right away and let me know what the exact error message is), quit Disk Utility.
• Now relaunch Safari and let's see if it launches ok for you.
If this is still not resolving the issue you are having with Safari, just let me know.
Regards,
-Mactechtrainer
Feb 01, 2010 | Office Equipment & Supplies
Safari table width problem
Jun 03, 2009 | Apple safari
Even after setting up my fonts with CSS, when I check the home page I'm designing with either the Firefox or Safari browsers, all my fonts come out as Times, even when some of them are Arial. Am I not
which version of QuarkXPress are you using?
You can try creating a Preferences folder under (Remember p should be in upper case) HDD>>Applications>>QuarkXPress folder and then check the results
May 30, 2009 | QuarkXPress 7 Full Single User Mac/Win...
Jumbled text
You need to clean your Font Caches whenever and wherever you get garbled text ... I use a free utility called MainMenu which does this (a restart is required afterward) and many other maintenance tasks.
Have you changed your Text Encoding settings, by chance, in either the View menu or Safari preferences?
Jan 27, 2009 | Apple safari
Apple safari Logo
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
