Need new cleaning tool
SOURCE: ionic breeze 3.0 repair
My Ionic Breeze GP began losing power occasionally but I could shake it and get it to turn back on. It got worse and worse until it would not turn on anymore.
The problem on mine is the micro switch that detects whether the collector plates are inserted or not, so it is part of the safety mechanism. There is a about a one-inch cylindrical piece of plastic on the front of the collector plate handle. This cylinder goes through a hole and pushes on the micro switch (actually a plastic cover over the micro switch).
On mine, it appears that arcing inside the switch caused it to get hot, deforming the plastic a little bit and apparently ruining the inside of the switch.
The following URLs describe the switch, but I have not found a retailer that carries it:
http://www.dicgroup.com/pdf/SM/SM5-01N.pdf
http://www.dicgroup.com/e-pro01-sm.html
Another of the same model switch is used in the back of the unit to detect whether the rear cover is on (over the UV bulb).
If I cannot find a replacement, I am thinking of either bypassing the bad switch entirely or swapping the switch from the back. Either way would defeat a safety feature so it's probably not to be recommended, but I consider the sacrificing the switch for the back cover to be introducing only limited risk, so I might take that route if I have to.
SOURCE: my ionic breeze has quit
i have the same problem as well as my on button keeps going off and on...
SOURCE: Professional Series Ionic Breeze Tabletop
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
SOURCE: Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
