Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Will not spray solution. Belt is not broken.
    Problem Solver:
  • 9 Answers
Clean out the line were your solution comes out. It sounds like you have a build up of product solution . Check your products you used . Some cleaning product are very sticky. Best of luck Ed.
Posted on Jun 18, 2009
Motor turns on, but brush won't turn. belt is not broken
Sometimes hair and debris get in the end of the rollers and keep them from turning. Also, the bearings can become corroded and stick. Try removing the rollers and check for any debris and remove it. If the bearings are stuck, you can spray some lubricant or WD40 or them and try to free them up. On occasion the belt can come off of the motor. You can turn the unit over and see if the belt is moving over the roller. Good luck and let us know how you made out.
Mar 04, 2010 | Bissell 3920 Bagless Upright Vacuum
Won't spray wate rwhen you press trigger.
When the water won't dispense that usually means that the pump belt is usually stretched or broken. Here is a link to the belt you need and a manual you can view:
Bissell 7920 Belt and Manual
Dec 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
My bissell cleaner bottom brushes are not turning and the big tank of water is not working only the small stain tank is working. it is still sucking up the water
Check the brush drive belt has not broken by inspecting from underneath. See the manual pages 21 & 22 for removal instructions. Download a copy from the following link
http://uk.bissell.com/images/UserGuides/9500E.pdf
This may be caused because the pump belt has stretched or broken or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Main causes for no spray.
Bladder may be empty.
SmartMix Bottle may be empty.
The Filter may be clogged.
Tanks may not be seated properly.
Pump may have lost prime.
The Pump Belt may be broken.
2 front jets are blocked. This is a common problem. When the machine is standing for a while the detergent turns to a gel causing the blockage Lay the Bissell on its side then where the water comes out of the jets at the bottom of the machine unblock them using a pin to poke through the hole in the centre.
Try running hot water through the system with no detergent to empty out all the residual detergent. Keep running hot water through the system by pressing the button you press for it to spray the water do this for about 5 mins and keep swapping the water for hotter water as it starts to cool doing this 4 or 5 times might solve your problem if not get the tools out and start looking for the blockage. Do this once a month to ensure that the pipes and jets are kept clean and free of any detergent gel build up.
Nov 13, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Can not get the cleaning solution to go on the floor when i want it to.
This sounds as though the pump belt is slipping and burning. This may be caused because the pump belt has stretched slightly or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Oct 18, 2009 | Bissell 8910 ProHeat Clear View Upright...
Machine suction works but will not spray liquid. Belts are ok but are not turning. Shaft gets hot and there is a burning odor.
Oct 14, 2009 | Bissell 8910 ProHeat Clear View Upright...
No water on carpet but apolstry cleaner will spray
Buy a cow... Literally. I did and it worked right when i bought it. My cow's name is Susie.
Jul 11, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell proheat 12 amp will not spray water on to the carpet,nor will the hand tools spray water?
The water is pumped via the belt that drives the pump. Remove the belt pump on the left side of the unit using a screwdriver and prying upward in the slot in the rear of the belt cover. The belt cover has holes in it. Check to make sure the belt is not broken. If it is replace, about $3-4.
Good Luck
Feb 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7920 doesnt spray liquid
Ive oredered the pump belt and brush. after receiving and fixing them i will test the spray if it works.
Aug 18, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
203 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
