Question about Garden
Cub cadet 959468
How do I change oil?
  • 140 Answers
Remove the wire to the spark plug. Then turn the mower on its side with the muffler facing up. Locate the square plug on the bottom of the mower. Loosen this bolt and place a pan under the mower to collect the waste oil.
Posted on Jun 03, 2014
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
SOURCE: I HAVE A CUB CADET GT2542 RIDING MOWER. I CHANGED
There is no way to reset it. It will stay on until the hour meter reaches 102 hours and then the light will go out
Posted on Jun 13, 2009
  • 202 Answers
SOURCE: how do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Posted on Jul 08, 2009
SOURCE: how do i reset the change oil light on a 1040 cub
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Posted on Sep 01, 2010
My 04 cub cadet m60 tank with a 27hp Koehler just up and quits after 20 min. I just changed oil and filter and "change oil " is blinking. Help
I'm not a Cub dealer but the "change oil" light should reset itself after usually an hour of use. check the oil level for the no start. if it has an oil level switch and is low, there will be no spark.
Jun 01, 2016 | Cub Cadet Garden
What type of oil do i use
(32 degrees and above, 30w oil) - (32 degrees to 0 degrees, 10w-30) - (32 degrees to -20 degrees below 0 and beyond -20, 5w-20 or 5w-30) Cub Cadets call for a low ash oil. it can be purchased at any cub cadet tractor dealership.
Jan 21, 2016 | Cub Cadet Snow Blowers. 28 in. Two-Stage...
2015 Cub Cadet XT2. Where can I get a manual?
There is a Cub Cadet App that lets you connect to your Cadet and monitor status, like oil change due etc. It also has built in manual. Check it out
http://www.cubcadet.com/equipment/CubCadetFullPageArticleDisplayView?langId=-1&storeId=10051&catalogId=14101&pageView=Cubcadet_General/CubConnect.html
Aug 07, 2015 | Cub Cadet Garden
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Cub cadet troubleshooting
unhook battery wait 20 secondes hook battery back up fault should be gone or you have a bad oil sending unite cost 20.00
Aug 28, 2014 | Cub Cadet LTX1045 2009 and After Deck Belt...
How do I get rid of the 'Change Oil " Alarm after the oil change
Oil alert on the hour meter cannot be re set, it will stop itself after so many hours, crazy system!!
Mar 31, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet walking mower, model 959468 can not pull cord to start
there is a the cable that goes to the handle you need to hold that releases the engine brake
Apr 04, 2012 | Cub Cadet Garden
Cub Cadet LT1045 oil light is flashing at 50 hours. Changed oil at 45 hours
I am thinking that might be a notice to change the oil, which is only for notification purposes. Check your owners manual. There may be a procedure to reset the timer when you change the oil.
Sep 04, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet oil changing? Every when?
general rule is to change oil every 50 hrs and even more frequently if used in hot / dusty conditions or with heavy loads , check oil before each mow , and clean air filter every 25 hr
change oil filter every 2nd oil change at least
cheers paul
Aug 02, 2010 | Cub Cadet Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
