Question about Empire Comfort Systems Empire Protractor/angle Finder - Protractor/angle Finder
Angle finder instructions - Empire Comfort Systems Empire Protractor/angle Finder - Protractor/angle Finder
How do you set the finder scope on the Starview 150EQ. I have no adjustment options and it is not in line with the main telescope alignment. The instruction manual is totally inadequate.
Place a wide angle, that is longer focal length lens in the scope in daylight and focus it and centre on some distant object, a tree, blg, tower etc.
Then use the adjustment screws on the finder to centre it on this same object.
Change to your next higher power lens, that is shorter focal length, refocus and centre, and repeat with the finder adjustment.
Next wait for evening and a bright star or planet to appear and centre it in the finder first this time. It should be somewhere near centre in the lens also. Centre it properly in the lens and make a final adjustment on the finder.
Dec 30, 2016 | Optics
Cant get an image.Is it right that the view finderimage is upside down
The image of all astronomical telescopes are upside down (SCTs are upside down and reversed). RACI (right angled, correct image) finders do produce a right-side up image. For daytime use a erect image prism eyepiece.
Follow below instructions (except 7 in your case)
  1. Get Stellarium or another fine astronomy program
  2. During the day, point the telescope at a part of the landscape about 100 yards away.
  3. Use the lowest power eyepiece (highest number) in the focal tube.
  4. Center the landscape object in the telescope.
  5. Align the finder scope so that it points exactly where the main telescope is.
  6. At night, leave the scope out to reach thermal equilibrium (about an hour for small reflectors and refractors)
  7. If the scope is on a EQ mount, polar align.
  8. Point the finder at the moon. The moon should be in the main scope also.
  9. Practice finding the moon before you start on the planets
  10. Once you are comfortable with the moon and planets, you can go for the deep sky objects
Feb 28, 2013 | Vivitar Viv-tel-76700 75x/350x Reflector...
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
My Bosch DWM 40L angle finder has locked itself on 888.8 and I can not swithch the machine off, even when I put in new batterie it does not correct itself, please can you help.
Open the the moveable arm and make it straight (180 degrees) or in line with the other.Take the screw off of the black cover at the elbow (1 screw). Lift from the round part and lift off. Then loosen the two screw just inside the cover. This will allow the flywheel to spin and you should now get a read out. If the flywheel does not spin then you need to replace that piece. Gently tighten the two screws and put the cover back on. Hope this helps!
Aug 15, 2011 | Bosch DWM40L Miter Finder Digital...
Battery compartment in my angle finder overheats and battery indicator comes on a brand new set of batteries . why is that? i put a fresh set of batts.and when i turn it on the batteries on the right get...
There is an electronic component that is defective and it draws a lot of current (more than the normal rating) this makes the batteries over heat, if it's new ask for replacement of the tool.
Cheers!
Jan 12, 2011 | Bosch DWM40L Miter Finder Digital...
Unable to make a straight cut with saw. Tried adjusting tension, lowered blade, made sure blade aligned properly and did not feed too quickly. HEEEEEELLLLLLLLLLLPPPPPP! Thanks in advance.
Hello, I think that the problem you are having is called "drift" . each blade will cut different than the last. The way I was taught to cure this goes as follows.
-take fence off off table(or just move over)
-get a good square piece of material appx. 1x3 and mark a straight line about 1/2" from edge the full length of the board.
-with out the fence cut the board along the line appx. 1/2 the length.
-shut off saw WITH board in it.
-use a angle finder along the edge of the board, set angle finder
-remove board and put the fence back on.
-now slide the angle finder up to the fence, you should see that the angle is different than the fence (this is the DRIFT ), adjust the fence to the angle finder( I know that the smaller saws usalley don't have this adjustment ) you will have to find a way i.e. shim etc.
This is a very common problem but once you get the idea it is a easy fix
Remember: A guy taught me and I taught you, pass it along thats what we do.LOL
Hope it helped.
The Shop Dog
Oct 23, 2010 | Ryobi 9 in. Benchtop Band Saw
I was looking to print out instructions for conduit bending
Invest in a bender if you want to bend thin wall. About $15.00 at Ace Hardware.
Oct 30, 2009 | Swanson Magnetic Angle Finder
How do I read a multi-purpose angle finder? Do you take the top or bottom measurement as your angle?
It depends on what you want to measout. For less than a 90° angle, use the numbers below 90°. For angles more that 90° use the numbers above 90°. A flat surface has an angle of 180°. At any given point. If you make a point somewhere in the surface, and raise an end 1°, The angle @ the pivot point is 179°.
Sep 24, 2009 | Measuring Tools & Sensors
Skil 2100daf angle finder
I was trying to reset the zero on my angle finder. It's a Powerfist Digital Angle Finder, the same as the Skil 2100.
After turning the unit on, if I press the Miter and Hold button together and hold them, the unit goes into 'calibration' mode. (The display flashes 0.0). If you do nothing, it will always stay in this mode forever after that.
You can then reset your unit - it takes time however and patience.
With the aid of a large protractor, draw angles on a large sheet of paper (I used a couple of 11 X 17" pages) from 0 degrees all the way up to 220 degrees.
Turn on your angle finder and make sure the numbers are flashing 0.0. This will be your 0 degree reading. Hold the finder closed and press the Hold button once.
The display will now read 10 degrees. Open up the finder until it matches your 10 degree marks on your paper and press the Hold button again.
The display will now read 20 degrees. Open up the finder until it matches your 20 degree marks and press the Hold button again.
Continue setting your angles in this fashion up 'til you reach 220 degrees. The next button press will close the calibration cycle and the numbers will stop flashing.
Your unit is re-calibrated. Now, if it's off - you've only yourself to blame.
Apr 23, 2009 | Skil 2100DAF Digital Angle Finder
Empire Comfort Systems Empire Protractor/angle Finder - Protractor/angle Finder Logo
113 people viewed this question
Top Empire Comfort Systems Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Empire Comfort Systems Measuring Tool and Sensor Expert? Answer questions, earn points and help others
