Question about Bunn NHB Coffee Maker
Bunn nhs-b leaks how to take top off - Bunn NHB Coffee Maker
Ours was leaking as well.
Unplug the machine first. The entire top just snaps off in one piece. When you have this off, gently snap out the pivoting arm you are looking at that has a clear silicone cover over the drain to the tank. This needs to be cleaned along with the top resevour. Remove the brew basket (where you place the filter). Tip the unit upside down and drain the water. Unscrew the spray nozzle. There are two Phillips screws that need to come out. Remove them and then gently pry off the bottom section as well. It pivots from the back.The on/off switch will probably come out of it\'s mounting when you do this so take a good look at how it\'s placed so you can snap it back in when you go to reassemble the unit. The stainless steel band around the top of the unit will probably come off at some point during dis-assembly. This is just for looks so if you don\'t want to bother with the hassle of getting it back in place, don\'t worry about it.
There is a silicone tube that attaches the bottom to the top. Pull this off for cleaning.
Clean everything you see with white vinegar. Do a good job, soaking the tube, flapper, spray nozzle etc. If you saved the package that came with it when you bought the unit, there is a long, thin brush for cleaning the drain tube. If you don\'t have that anymore, pipe cleaners will work but be careful you don\'t poke a hole in the silicone tube.
Leave the pivoting arm off the top of the fill tank and fill everything with white vinegar and let it soak. Dump it out and be amazed at all the crap that comes out. Do this a couple of times until nothing more comes out. Reassemble the entire unit making sure you get the silicone tube securely in place. This is a pain but take your time and do it right or it will leak. Fill everything with water and run it for a few cycles until it is flushed out. About once a month or so, dump out all the water and fill the tank with white vinegar, let it soak and then run a brew cycle with vinegar instead of water. Flush as above.
The siphon, drain tube and spray nozzle get clogged with calcium and this is what causes the leaks.
Posted on Aug 17, 2014
Bad leaking bunn commerical VPR pour-omatic
You will need to replace it, parts are not made for repair except under warranty.
Nov 30, 2016 | Bunn Coffee Makers & Espresso Machines
Brand new! Cleaned it out with vinegar initially, poured in and turned it on. Still waiting, nothing is coming out at all. What's the problem?
LOL add another pot of water it has a storage tank of 1 pot ..it might take several pots to get all the vinegar out .
Dec 22, 2015 | Bunn O-MATIC NHS 10-Cup Professional Home...
HOW DO I STOP A LEAKING BUNN COFFEE MAKER NHBX-B
Go to UTube - there are some good videos out there on how to fix this. You have to take the top off and clean the flapper.
Jan 25, 2015 | Bunn Coffee Makers & Espresso Machines
Bunn coffee pot leaking bottom
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Oct 02, 2014 | Bunn Coffee Makers & Espresso Machines
How to fix a leak on a bunn NHBX coffee maker
Aug 09, 2014 | Bunn NHB Coffee Maker
My brewer leaks from base of the brewer
Either leaking from tank lid or fill basin.You will need to take of top of brewer to verify.Parts and breakdown available at the Bunn website.Contact customer service at Bunn.I know at one time they would replace the brewer at a discount rate.
Feb 10, 2011 | Bunn A10 Coffee Maker
Hi i have a bunn that leaks but there is a screw
The NHB doesn't have a replacement seal but if you will call Customer Service at 800-352-2866 we will be happy to further assist you in resolving your issue.
Jun 03, 2010 | Bunn NHB Coffee Maker
Leaks water from the top resevoire
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
Feb 01, 2010 | Bunn VPR Coffee Maker
Unit leaks water from bottom bunn pouromatic
What model of Bunn is this? If it is a bx-b or any of the other home models, what has happened is that the plastic pour-in tray has become brittle and cracked where it mounts onto the tank. The only repair for this is to replace the tray with one from another brewer (possibly your local bunn Dealer has an old brewer lying around). If it is a commercial brewer (VPR, VPS, Ect) there will be a sael leaking on the top of the tank.
Nov 26, 2009 | Bunn Coffee Makers & Espresso Machines
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
1,086 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
