Question about Dell PowerEdge Computers & Internet
Cpu fan stopped start server - PowerEdge Dell Computers & Internet
  • tony wahlman
    tony wahlman Aug 18, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
2 Suggested Answers
MPetro302
  • 298 Answers
SOURCE: it start my pc but it stop including cpu fan
order a newone from places like newegg.com
Posted on Jun 04, 2009
Automatic shutdown
Check the CPU Fan and make certain it is functional. Some computers do an auto-shutdown when the CPU reaches a certain heat ratio upon starting. Make sure the power conncetion is on firmly.
Jan 13, 2014 | HP Computers & Internet
Shuts down 2 seconds after powering on.
Don't know this exact server. But my guess it is either a heat issue or a power supply issue. Turn it on with the cover off. Check the CPU fan(s). If your CPU is getting too hot the system might be shutting down power to save it. If everything seems cool it might be the power supply I have seen it when the power supply fan goes out on the power supply and the caps inside start to sizzle. Voltage ramps up and fail.
Hope this helps.
Also, Something that has tripped me in the past. Make sure the power button is not stuck. I had a server that the power button stuck down and it would turn itself off. Took me 2 CPU fans and a power supply to figure that out. LOL
Oct 08, 2013 | HP ProLiant DL385 Server
PC won't start up
It may be worth trying to re apply the thermal paste to the processor, make sure you remove power from the machine before you open it up. The CPU may have failed, but they don't fail very often, so try the paste first, it will only cost a few GBP for a couple of applications.
Sep 23, 2013 | Sony VAIO VGC-RB34G PC Desktop
Power supply
Bad A) Video card B) Memory chip C) CPU or CPU fan
Jun 06, 2013 | Dell PowerEdge T100 Server
I have an IBM x346 eserver that has run well for years. The fans are now very load (whirling noise). I typically only hear this noise when the room temp is high, but this server is in a cool room with no...
It sound like the CPU fan or server case fan/s or power supply fan bearings are worn.
To determine which fan/s is faulty open the computer case and stop each fan from spinning, one at a time to determine the noisy fan. Once you have identified the noisy fan then replace that fan.
Feb 07, 2011 | IBM xSeries 346 Server
Main MB powers on for about 15 sec then shuts down, power supply and front panel control both good, how can i get replacement MB
Check the CPU heat sinks and fans. Replace heat transfer material. If it powers up and doesn't stay on very long, it could possibly be detecting overheat or cpu fan stopped and shutting down.
Aug 12, 2009 | Intel Server Platform ISP1100
No display cpu fan are'nt running though there is green and orange light on server
Hello there,
Check your power supply and see if its functioning.
CPU fan that does not run means there is no power getting into the motherboard.
Thank you for using Fixya
Apr 06, 2009 | Fujitsu Siemens PRIMERGY P200 Server
Boot-failure
I habe exactly the same problem. I habe the P45 Neo3 Board with E8400 CPU and 4GB Dominator RAM(1066MHz). No signal aber reboot. A Bios-Reset helps vor a Moment, but after Restart, i habe no signal.
Jun 16, 2008 | Intel Motherboard
Server starts to boot then powers off.
Check your CPU cooler. If it is not properly mounted your CPU/s could be overheating. There is a safety mechanism in Pentium chips that shut down the processor when it reaches a certain temperature. If your heat sinks are mounted correctly, check your Heat sink fans. Ball bearing fans are notorious for making a little noise then quitting.
Jun 10, 2008 | Intel Server Board SE7505VB2 Motherboard
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
Computers & Internet Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
