Question about De'Longhi BCO330T Combination Steam Espresso, Drip Coffee, Cappuccino
Bco330t leaking Leak is at the boiler outlet. I suspect that the gasket that seals the boiler outlet/filter holder interface needs replacement. While brewing, most of the boiled water flows through the coffee in the filter holder, but some boiled water flows down the outside of the filter holder without passing through the coffee grinds.
Oil leak on driveway coming from front of engine
Dear Sir,
Here is the oil leaking Problem Identifying Technique
Engine oil leaks from the valve cover gasket are common.
  • The intake manifold plenum gasket may leak and cause increased oil consumption/burning and a spark knock during acceleration; the gasket should be replaced.
  • External oil leaks from valve cover gaskets, intake gaskets (front or rear), and the rear crankshaft (rear main) seal area are common. The rear main seal is an unlikely source. Normally, the bearing cap mating surfaces (as well as the sealing surface between the oil pan and bearing cap) are the source for the leaks.
  • Engine oil leaks at the distributor can be misdiagnosed as leaks from theintake manifold seal, oil pan gasket, or rear crankshaft (rear main) seal. A revised distributor is available if oil is found inside the distributor.
  • If the oil filter casing shows signs of distortion from excessive oil pressure, theoil pump should be replaced.
  • Often misdiagnosed as a leaking oil filter gasket, the oil filter adapter can seep from between the adapter and engine block.
  • Carbon buildup on the top of the piston is common. As the buildup increases with mileage and over time, symptoms may vary from light ticking, to ticking/hammering, to hammering/knocking noises. Fuel injector cleaner often solves the problem.
  • I think it helps to analyse u r Problem
    Nov 02, 2012 | Toyota Cars & Trucks
    There's is water leaking inside my Saeco Magic Deluxe superautomatic espresso machine. Is it a bad boiler?
    i had a similar problem and found it was just a gasket on the boiler that wasnt sealing properly.i used JB WELD to repair mine.check all connections and/or gaskets for signs of leaks or possibly a broken gasket mating surface.
    Dec 30, 2011 | Saeco Magic De Luxe Espresso Machine
    Water leaking from the left side
    Hi
    There are a few things that will leak on the left side
    1. The boiler can leak if not descaled regularly or properly.
    2. The steam boiler can start leaking around the o-ring gaskets or tubes.
    3. The steam valve o-ring can wear out and leak.
    Boiler will show whitish scale between the halves and will need to be replaced. The others are just replacing the seals or tubes.
    May 16, 2011 | Saeco Magic Comfort Plus Espresso Machine
    When brewing with the X1, water starts leaking from the underside of the top where the brass filter holder connects to the machine. Tightening the 4 nuts did not help.
    HI
    More than likley its your brew head gasket that is leaking. Take off the 4 nuts you hust tighten and it exposes the brew head gasket. Make sure that you put the chrome piece on the same way you took it off. Clean the head good before you put the new gasket on or you could have trouble.
    I would check ebay.
    Jan 31, 2011 | FrancisFrancis! X1 - Stainless Steel...
    Trying to track down oil leak need cutaway to help find possible locations on engine that could leak motor oil
    Best is to pressure wash it - then run and inspect it after the run.
    If it's at gearbox join - suspect main crank seal
    If it's near oil filter - replace gaskets there.
    If near cambelt - expect to replace seals behind there.
    Or head gasket.
    Dec 27, 2010 | Ford Escort Cars & Trucks
    Water is leaking from inlet/outlet area. is that a heat exchanger problem?
    If there is a water leak in between the pool/spa plumbing and the inlet/outlet manifold, it just needs a new gasket if it is a plastic manifold, and if it is a cast iron manifold, the 2" threads for inlet and outlet need to be unthreaded, then coated with a pipe sealant (non-teflon) then rethreaded.
    If this leak is in between the outer and inner inlet/outlet manifold peices, then a new gasket is needed. The part number for that gasket is: 006713f.
    If the leak is coming from inside the cabinet and leaking down the interior or exterior, it could be a heat exchanger issue.
    The most likely event is that the o-ring that seals the header manifold is worn and needs to be replaced.
    This would take about 30 minutes of labor and an o-ring.
    Please vote positively if this has helped.
    Nov 01, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
    How do I fix a leak from the coffee holder unit
    Does it leak around the pod holder, or after the holder is removed?
    It it is around then you need to replace the head gasket.
    If it is after then the solenoid or the valve seat is damaged.
    May 01, 2010 | Breville ESP8XL Espresso Machine
    Mx5 mk2.5 slight engine oil leak.
    Can you tell us more?
    How many miles on the car?
    Which side of the engine area? Drips after you park etc?
    Oil ever low? If so how often do you ad oil?
    Any visible oil on engine and bay components under hood?
    likely areas for oil leaks may include depending on model and make:
    Oil pan gasket seal.
    Oil pressure sending unit.
    Oil filter installed dry or over tightened at your last oil change.
    Oil drain plug loose or plug gasket needs replacing.
    Valve cover gasket needs replacing.
    Crank shaft seals need replacing.
    Distributor seals need replacing.
    RTV gasket sealer beyond expected life and need replacing for other engine components, inspection plates or covers.
    Sep 21, 2009 | 2002 Mazda Miata
    De'Longhi BCO330T Combination Steam Espresso, Drip Coffee, Cappuccino Logo
    50 people viewed this question
    Top De'Longhi Coffee Makers & Espresso Machines Experts
    De Brewerz
    De Brewerz
    Level 1 Expert
    Tom Chichester
    Shrikant Shinde
    Shrikant Shinde
    Level 1 Expert
    Are you a De'Longhi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
