Question about Craftsman 2500 PSI Briggs Stratton Powered Pressure Washer
Type of oil used on craftsman power washer - Craftsman 2500 PSI Briggs Stratton Powered Pressure Washer
2 Suggested Answers
  • 11 Answers
SOURCE: Can I Use 10w-30 or sae30 motor oil in my 2700psi
10w30 will work fine. you also can use 15w40 depending on how hot your summers are. you can stay with 10w30 just check it depending on how long at one time you use it. if your just occasional, check twice throught the summer and add or change if needed if commercial go with 15w40 and check every day.
Posted on Jul 06, 2011
Location of pump oil input valve
Hi
Im surprised that this model pump has a oil refill. Most pumps of this size arent refillable. This looks to be a pump made by FAIP. Its an ok pump but I would recommend using it until it fails and then replace with an AR RMW pump. Much easier to get parts for. Here is a diagram of your pump...The oil refill plug is on the side of the pump...that is located under your engine. You want to get the recommended oil for your pump. Most pump oils are 30 weight non-detergent but these small pumps take an oil specific to only them. So follow your specs...your diagram is here http www searspartsdirect com Craftsman Power washer Parts Model 580752330...
and your manual is here 580752330 CRAFTSMAN PRESSURE WASHER Manual
Hope this helps
Sep 20, 2014 | Craftsman Garden
Can I Use 10w-30 or sae30 motor oil in my 2700psi 2.3 craftsman power washer?
Jul 06, 2011 | Craftsman Garden
What type of oil do I use for Craftsman 42" Briggs & Stratton 17.5 hp Gas Powered Riding Lawn Tractor for oil change
Only use SAE 30 if using conventional oil. Briggs is real specific about that. I highly recommend using synthetic oil in ALL lawn equipment. You can use a multi-viscosity oil like SAE 10W-30 if you use synthetic, but straight 30 weight if using conventional. The brand is up to you.
Jun 08, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
Oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
Oct 03, 2009 | Briggs & Stratton Garden
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Power washer will not draft
craftsman 2000 psi, model 020211, starts up and runs good just lost pressure?
Jun 09, 2009 | Briggs & Stratton Gas Pressure Washer...
Craftsman 2500 PSI Briggs  Stratton Powered Pressure Washer Logo
67 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
