Question about Jenn-Air Cooktops
Cve3401b 12002125 Connection part 12002125
Jenn-air CVE3401B cook top-How do you remove the wiring box cover?
if you lift up on the whole unit you will see the screws that go all the way around the unit under the glass lip.
Jun 06, 2011 | Jenn-Air JED8430 Electric Cooktop
I ordered a replacement switch for the JED8430ADW. The previous switch was 7403P406-60. The replacement switch is 12002125. I have no clue how to re-connect the wiring. it looks nothing like the old...
There was a design change related to this switch. I had the same problem earlier today and figured it out by getting the schematics from searspartsdirect.com. There are two different schematics there (in English). The old schematic is labeled "DIAGRAM NO. 8104P688-60". The new one has five notes in the lower left (that don't help). The key is to split out the red wire coming back from the double burner element. The old way had it connected to "N" along with the RED source power. The new way has it connected to terminal "2" all by itself with the RED source power now connected to terminal "P2". But in addition, you have to add an extra jumper wire that should have come with your new switch that goes from "P1" to "S1". The other connections simply move from the old switch to the new where the locations can be seen on the schematics by referencing the wire colors (example: TAN wire moves from the old "3" to the new "4", etc.). If you are not 100% sure of what you are doing - you shouldn't try this. A wrong wire in the wrong place can short out 240V when you throw the breaker (boom!). Good luck. -- Mark.
Sep 10, 2010 | Jenn-Air JED8430 Electric Cooktop
I have a Jenn-Air cve3400 cooktop. The dual radiant burner doesn't work properly. The inside portion of the burner doesn't work by itself or in tandem with the outside portion of the burner. Is it the...
I just went thru this problem. There are TWO possible switch replacement parts. one is 12002422 and was my correct replacement number.
12002125 was the WRONG part..would not work no matter how you wired it. the failed switch being replaced was part number 7403p406-60. 7403p851-60 will NOT work.
my serial # was 12284711qz
call Jen air customer support and give your serial # and switch part # to get the correct part and diagram... Jenn air changed parts and wiring in the middle of a run.
Aug 14, 2010 | Cooktops
How do I replace a broken dual infinite switch on my Amana AKT3040SS ceramic cooktop?
raise cook top out of counter and remove screws holding glass top to base . remove glass and on the right is switch bank two screws holding each / remove and do not pull wires. but transfer one at a time noting that markings on old sw match new . . sw pt # is 12002125 and cost 49.35. and reinstall in reverse.. hope this helps . and do turn off the power before you start. mm good sailing .,
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
I need instructions for wiring in replacing a dual burner switch on a CVE3400B cooktop. The replacement switch is different from the original. Do you have a diagram for the new switch that shows how to...
We followed the instructions that came with the switch that addressed a "compound wiring" configuration. We also used the black jumper wire as shown in the instructions.
We got to this solution in a trial by error manner though, because the three of us working the problem were convinced the stovetop was wired in a "piggyback configuration" and tried that road first. It would have been helpful if the instructions had included an explanation of the switch manufacturer's interpretation of "compound" and "piggyback" configuration.
Jan 09, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Need To Replace the Cooktop of my Jenn-Air downdraft
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Apr 25, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Installing Smeg Gas Hob PGF75-3 Ultra Low Profile.
yes u can install it at the top of the drawers but check the gas connection before closing the drawers to make sure ther no problem,the inlet gas connection is in rigth side facing to u.
Nov 28, 2008 | Smeg Cooktops
Broken glass cook top
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
Jun 26, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
Cooktops Logo
63 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
