Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
SONY DCR HC 20
Touchscreen LCD panel wont work! m not able to calibrate it like the manual says. The x is changing at all no matter how many times i pressed it! I can record the tape but m having trouble with playback because the LCD is not changing when i press it
    Sergeant:
  • 321 Answers
Due to open & close screen your screen belt has damage. send to us for service.
Posted on Jun 18, 2009
My sony handycam dcr-hc21 won't respond to touch on the touchscreen anymore. I can't rewind, play, etc. I also don't know where the reset button is on this model, or how to calibrate. ...
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony at a reasonable price for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Oct 25, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
Hello. my touchscreen isnt working and I am calibrating it. how long does it take to calibrate the screen? it seems to be going over and over again
This most likely a defective LCD / Touchscreen module and is no longer available from Sony at a reasonablw price,. However, I have a limited supply of them as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sep 11, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a Handycam digital video camera recorder- DCR-HC30. The camera sat in its carrying case at room temperature for about two years without being used. When I went to use it, the touch screen would...
The LCD / Touchscreen module is no longer available from Sony for this Model. However, I have a limited supply of them.
Feb 08, 2011 | Sony Handycam DCR-HC30 Mini DV Digital...
When I turn on my handycam sony DCR-HC 35,the touch-screen don't work!? What can I do about it?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Jan 05, 2011 | Sony DCR-HC35E Mini DV Digital Camcorder
Touchscreen wont work and can't get the calibration screen to appear as described in the manual. It keeps showing the initial date setup screen.
This fault is often caused by a failing flat cable that connects the LCD panel and the rest of the camera. In its early stages it is possible to get the buttons on the touch panel to work by carefuly changing the angle of the LCD panel while trying out the buttons until you get a position where they work.
When the flat cable gets worse , the picture on the LCD panel will start deteriorating and go off altogether.
At this stage you may consider having the flat cable replaced.
Oct 10, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
DCR-HC40 LCD works, but Touchscreen doesn't. I was able to calibrate once -- but din't hold settings. I cannot calibrate.
hello its ruttine problem ,just change the lcd FLAP and you can use the touchscreen.its not to wory about that
Aug 25, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
The buttons on my lcd screen does not work anymore. I tried calibrating it, but it just stays in calibrating mode as if it is not calibrating. this is for the DcR hc21
hi, if your lcd's touchscreen is not working only,then not to worry about just replace the lcd flap and its done,its very easyly avilable and easy to replace
Aug 25, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Board dcr-hc 32
dear sir
good evening,
i have bought the sony handycam DCR-HC32. cam is working in order. but there is some problems. that the red colour on LCD is off. what is the reson.
pl explain the fault & repair reson.
thanks
kamal58_asr@yahoo.co.in
Sep 15, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
DCR HC-42 LCD screen problem
Hi i had the same problem and i got it for the second time. can i please know how to remove the camera so i can replace the strip my self. And do u have a service manual. if so can i know where to get one for my self. thanks
May 19, 2008 | Video Cameras
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
579 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
