Question about Bunn MCP My Cafe Single Serve Coffee Maker - Pour Over
Bunn My Cafe Single Cup makeer is leaking water from the Top
  • 125 Answers
SOURCE: bunn 10 cup coffee maker leaks around the top of the tank
Hello. I would say that you are going to have to call: For repair information, call 800-352-286. They don't usually supply commercial repair houses with part information, or you could try here:
http://www.bunnomatic.com/retail/service/service_form.html
They will be able to get you what you need with minimal effort.
Hope this helped, and thank you.
Posted on Mar 15, 2009
  • 4 Answers
SOURCE: my 10 cup Bunn coffee maker leaks from the top
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Posted on Oct 15, 2009
NewsView
  • 40 Answers
SOURCE: Coffee grounds overflow out of basket into top of coffee pot.
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
  • 131 Answers
SOURCE: Bunn 10 cup home coffee brewer is leaking from the
These models have a plastic pour-in tray just under the top lid. The plastic on these trays gets brittle over time with the heating and cooling, and they crack where they mount to the tank. The only real way to repair this is to replace the pour-in tray, but these are not sold anywhere that I have found. You might be able to find a used one at a Bunn dealer in your area.
I have seen some people do a temporary repair by putting a washer under the mounting bolt and sealing it with silicone, but this is a temp. fix at best. By the way, the reason that the water appears to be coming from the bottom of the machine is that there is no other place for the water to come out after it leaks from the top.
Posted on Apr 23, 2010
  • 189 Answers
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Posted on May 19, 2010
My bunn cafe red light flashes does not take water to tank nnot heating either. why?
my bunn has 2 switches one on the left side to keep it HOT and the front one when brewed to keep it hot . the side switch if off will not heat the water and will not let the front heater be turned on either which is lighted
Dec 14, 2015 | Bunn My Cafe MCU Universal 4-in-1 Single...
Why does it leak around the top of the K-Cup holder?
Too much pressure makes the poor seal around the spray head leak. It happened to me, too. Call Bunn. They sent me a new one free of charge. Plus, you have to use purified water and clean it regularly to prevent buildup like calcium from causing similar issues (I use a gravity water purifier, but it doesn't remove natural minerals). I've had mine a year and that was the only problem. Much better than the multitude of Keurigs I had before.
The awful difficulty opening the drawer will subside with use.
And, they stand behind the machine in full for the 2 year warranty, meaning they'll replace the whole thing free if something happens
Dec 08, 2015 | Bunn My Cafe MCP
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
Sep 22, 2014 | Bunn Commercial Bunn My Cafe Pourover...
How do i clean my cafe before first time use.
Add about a half cup of white vinegar to the water an run it through
the maker about three times.After that use fresh water about three times. should be cleaned out .
Apr 15, 2014 | Bunn My Cafe MCP
BUNN MY CAFE BAD TAST WITH COFFE OR HOT COCO
Try really cleaning the basket that the water and coffee or cocao goes into. If you don't really clean it well, it will have the taste of the last thing brewed mixed in with the new brew. Coffee followed by coffee should not be a problem, but coffee followed by cocao will give the cocao a coffee taste, and visa versa.
Nov 21, 2013 | Bunn My Cafe MCU Universal 4-in-1 Single...
My Bunn coffeemaker is leaking water after it stops brewing and the coffee doesn't seem to get as hot as it once did. It also only gives back 4 cups for a 6 cup brew.
if you unscrew the top there's a rubber seal in there that you might have to replace that causes the leaks. also clean your coffee maker regularly with vinegar.
my husband had to replace the seal in ours 4 times but after owning the same Bunn for 20 yrs it was time for a new one
Jan 18, 2011 | Bunn 10 Cup Home Coffee Brewer
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn MCP My Cafe Single Serve Coffee Maker - Pour Over Logo
18 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
