Question about AEG Santo 7085 KG Side by Side Refrigerator
I have santo refregtarer i have a problem with the temperature
Aeg santo fridge keeps freezing
Fixya will not let me post links today, or their "capcha" thing does not seem to be working properly, so I will have to try this another way.
I've done some research on your issue and it seems that should only happen if the temperature sensor goes bad, or the evaporator sensor. Each of the two parts cost less than 30 pounds each, so may be less expensive than tossing out the whole thing.
Try browsing to shop (dot) aeg (dot) co (dot) uk
Then in the search at the top right, type in "santo" and look for the two sensors and decide if it would be worth a try.
Oct 14, 2013 | Refrigerators
How do i set my temperature on my fridge freezer its a aeg santo ?
Hi
The santo was originally built with a standard thermostat, this is graduated from 1 to 6 where 1 is the warmest setting and 6 is the coldest, normally you would set this to btween 3 and 4 and adjust it slightly to your favourite.
Regards
Gordon
Apr 20, 2011 | Refrigerators
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
What does the flashing (warning?) light mean
Did you ever get any advice for this problem? Please repost if not.
Oct 22, 2006 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo 7085 KG Side by Side Refrigerator Logo
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
ashburton
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
