Question about Earthquake Sound PH800W.2 Car Audio Amplifier
Visonik V12D4 SORRY THIS IS THE CORRECT SUB. DISREGUARD THE V-128D4 Visonik V12D4 12-in 600 watt duel voice coil to aLegacy LA568Predator Series 2 Channel800 Watt BridgeableMosfet Car Amplifier withRemote Control Bass. HOW SHOULD I WIRE THESE FOR BEST SOUND? Thank You.
  • 2 more comments
  • kjack20 Jun 18, 2009
    Could you make a diagram on how my 2 12's would hook up to the amp?
    I have 4 prongs in the back of the subs negative and positive on each side of subs on the box.
    Sorry can you also send me a diagram for the series wiring for the subs i can't find the, remeber i have 2 prongs on each sub running to the back negative and positive.
  • kjack20 Jun 19, 2009
    Disreguard all the following questions all I need is a diagram showing how to wire the subs to the amp i have a - + and - +
    Thank You very much
    Novelist:
  • 150 Answers
I would wire the coils of each sub in series which would yield an 8 ohm resistive load per sub - and then wire the subs in parallel to the amp which would bring the resistance back to 4 ohms for a bridged load which will give you max power handling from the subs and draw the full power of the amp at the same time
Posted on Jun 18, 2009
  • hoyzee1 Jun 19, 2009
    i just read your reply a little closer- okay if there are four terminal posts per chamber on the box then just wire the subs normally to the posts on the inside- that way we are just dealing with the outside of the box- the wiring is relatively the same though- you will jump a short wire from the first negative to the next positive -so your connection for the amp will be at the first positive and the last negative for that speaker do the same on the other chamber of the box and wire them parallel to the amp -any questions call me -801-548-8352 names greg
I have 2 duel 12' 2ohm sub's and a blackmore bac m-50 2000 watt 4ohm amp and was wondering how to wire. Thanks!
boz word of caution is to be heeded. with 2x2 ohms per speaker, you can only use one, with the voice coils ran in series to increase the resistance to 4 ohm . take a single driver, and use the series wiring on with both of the 2 ohm voice coils.
wire positive from the amp into positive of one voice coil, then the negative of that voice coil to the positive of the second voice coil 9bridging with 6 gauge or so, as was also mentioned by a previous user), then lead the negative of the second voice coil back to the amp's negative terminal.
Jun 01, 2015 | Car Audio & Video
How do I hook up my 10 inch visonik sub woofers? they have 2 connections?
this is a dual voice coil sub. either have a 2 channel amp hook up to it. or have your mono amp have to sets of wires going out of it to your 2 connections. i dont suggest it but i have had one connection hooked up at a time played it when it blew hooked up the other connection as a back up. just make sure you have the right watt level for each voice coil.
Apr 14, 2010 | Visonik V10DV6W Car Subwoofer
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Capacitor
You usually don't need a capacitor because your car can keep up with the power requirements, especially since your system isnt too big (no offense). But if you wanted to get one, i would only get a 1/2 or 1 farad cap.
Jul 26, 2009 | Legacy LA588 Car Amp
Sub box
it all depend on were you are putting these subs at. the dimesion on the trunk of a honda to a lincoln are vastly different
Jul 09, 2009 | Legacy (LA568) Car Audio Amplifier
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Subs
2x12 in sub each duel voice coil can iether wire to 1 or 4 ohms. im guessing you have everything wired up in series (1 ohm) and aer probably burning out the amp.
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DVC%5F4%2Dohm%5Fmono
Feb 25, 2008 | Car Audio & Video
Earthquake Sound PH800W.2 Car Audio Amplifier Logo
169 people viewed this question
Top Earthquake Sound Car Audio & Video Experts
hoyzee1
Tom Chichester
Are you an Earthquake Sound Car Audio and Video Expert? Answer questions, earn points and help others
