Qsc usa 1310 how to set dip switches
No sound
Qsc usa 900 power amplifier coming on but no signal.what can be the problem.I check all outputs
Are you then saying you have no sound, yet the amp is on? If so, with the unit off, listen carefully to the top of the amp. When you first push the power button, you should hear one click, followed by another click, about 5-20 seconds later. I'm guessing you hear the first click, but not the second. Is that correct? If this is correct, and you are interested in having your QSC repaired, Please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jan 22, 2015 | QSC Audio Players & Recorders
Qsc usa 1300
What is the impedence of the speakers on the unit?
May 13, 2013 | Audio Players & Recorders
I have a QSC RMX 2450 in which both channels are driven even though the amp is in stereo mode and I am only sending a signal into input channel one. It acts as if the amp is in parallel mode but I have...
My thoughts are that the amp has a poor channel separation but usually you can only hear a very quiet trace of the sound through the undriven channel. I agree with Taurus and make sure that the switch is making contact and moving all the pins to the proper points. This is a Home stereo amp, it comes with an extended 6 year warranty if you register it, I would check into getting a warranty repair before doing anything to it! Looks like a nice quality piece, those dip switches are a little bit confusing but the way it's built it is necessary to have them. It has a Dual Mono amp section so there is no way that any sound can be crossing over unless the swithches are directing it. The only way that can happen is in Parallel or in Mono. You could be in Stereo / Mono which would input both channels and output 3 settings a 1, 2 in Stereo & a Mono, Try hooking a speaker up to the Mono/ Bridge outputs and see if it's louder than just hooked up to 1 or 2. Parallel inputs will give you Mono 1 & 2 with Bridge off, and might give you Mono 1 & 2 with a bridged Mono if the bridge is on, like 3 channels all mono with one getting twice as much power as the 1 & 2 will put out. Although they have it labeled to not use it in those settings it's possible to do. I can see why you would be checking the switches.
It may actually be labeled incorrectly , as strange as it seems, many Chinese products have been made with labeling errors. Plus and minus have been wrong on Asian Made car amps so it's not that inconceivable that this may have some incorrect settings shown?
Apr 03, 2013 | Car Audio & Video
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
Want to set in english garmin nuvi 1310
  • Press TOOLS (The spanner icon in the bottom right corner of the screen with WHERE TO and VIEW MAP)
  • Press SETTINGS (The spanner icon) or LOCALE (The blue icon) on models without a settings menu
  • Press LANGUAGE (The lips icon)
This brings you to a screen with 3 items. VOICE, TEXT LANGUAGE and KEYBOARD. Press VOICE and select a voice from an English speaking country to get voice prompts in English.
Press TEXT LANGUAGE and select English or American English if you're in the USA.
Apr 17, 2011 | DURAGADGET Car windscreen / air vent mount...
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
How do I set up the amp to use two seperate channels?
On the rear there is a set of 10 dip switches switches 4,5,6,7 must be in the left land position. also look through the manual to get familiar for all settings. http://media.qscaudio.com/pdfs/manuals/RMX_User_Manual.pdf Good Luck, Cody J
Dec 05, 2010 | QSC RMX1450 700watt DJ Amp 2 Ohm
Quiet Amp
sounds like you need a preamp. i would need more info to be sure. good luck
Feb 11, 2010 | QSC CX302 2-Channel Amplifier
My QSC GX3 has a red light that turned on (on the front panel). The channel is not working. Is this a fuse or something else?
You should check the speaker set, maybe it's short circuit.
Try remove the speaker set from the unit, than switch on the amplifier again, if the red light still on, surely the final drive is damages( Transistors or IC's).
Replace it with new ones.
Oct 18, 2009 | QSC MX1500A 2-Channel Amplifier
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
43 people viewed this question
 Grubhead
Grubhead
