Question about Sony KP-65WV600 65" Rear Projection HDTV-Ready Television
Red Color problem Sony rear projection 65"
I have Sony KP-65WV600 and everything is great except the red color is moving to the right. I try the convergence but the red cross is moved to the right above 2 inch. Any help appreciate.
  • pawel k Jun 18, 2009
    The knob is located behind the front cover ?
    President:
  • 2,187 Answers
Looks like a problem in convergence. You can fix this by adjusting the one for the red color.
Adjusment
If it does not work you may want to check on the IC.
Posted on Jun 18, 2009
  • 583 Answers
Whether its half a inch or 2 inch but the only way to get it in position is through adjusting the convergence knob.if at all its not moving back to its position that means the convergence is faulty and at the end of its life.in that case its compulsory to replace convergence to solve the problem.
thanks and keep updated.
please do rate this solution positively.
Sony KP65WV60 CANNOT RECONISED RED COLOR AND WRITING FUZZY
First, try cleaning all your lenses & mirrors...THEN
considering the age of this unit, the red CRT is probably worn out. Weak CRTs are probably the problem with the fuzzy picture also.
You can try to adjust your screens (the screen adjusts are available by removing the bottom front) to bring in some red, and adjust the focus on each CRT for better focus. I'm thinking with the age of this unit you may need more than just the RED CRT.
If any parts are needed, My recommendation is to replace the unit with new technology. Would be more economical in the long run.
Apr 29, 2014 | Sony KP-65WV600 65" Rear Projection...
Kp-65wv600 looks like I'm watching a 3D tv but not tv isnt 3D It has a blue, green and red out line behind the person could it be the lamp light and if so what color
Hello sburdano,
Welcome, and thank you for using FixYa!
To answer your question: The colors are all working, they are just out of alignment.
Judging by what you have said hear, I would assume that the television have been moved, rather roughly, or bumped into rather abruptly. The color wheel will need to be re-aligned to the lamp and lens. You need to find out what your local TV Repair shop would charge for re-tuning.
Have a great day!
Dec 01, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Remote
If you have the original remote, it does not need any reprogramming because the Sony code will be the first one even if you change the batteries.
Try pressing the TV key on it if you have the RM-Y185 remote, also try to move the switch to the AV1 position.
Mar 28, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Color problems and tv shutting off
My tv screen turns red as it heats up and the repairshop told me it would cost $600.00 for a new red projection gun how ever I don't think thats the case because it is a heat related issue. I think an ic or transistor is going bad and goes into saturation when it gots warm. I will be spraing some components with freeze spray and if my hunch is correct the color will temporarly correct its self when I spray the right component.
Feb 02, 2008 | Sony KP-65WS500 65" Rear Projection...
Blue and red color are off, picture is not clear
convergence amp ic bad
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
SONY GREEN CONV OUT BLUE/GREEN OK,SONY KP-65WV600
Red,blue and green each have an amplifier IC--Stk392-560 x 2
Replace both IC's for reliable repair.Also,check  fuses,location sometimes ps5003-5008. fuse value 3.15 amp. ......T.
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-65WV600 65" Rear Projection HDTV-Ready Television Logo
139 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
