Question about HP OfficeJet 7110 All-In-One Thermal Printer
I bought a used HP 7110 and was told it worked good except for the FAX operation. I do not use the FAX. I bought two new ink cartridges. I have copied color material that I placed in the top of the printer. Problem: I cannot print from my Apple computer E-mail file or from my stored files.
  • julianandjan Jun 18, 2009
    At System Preferences the only printer was J5700. I obviously need software for 7110 but I don't have any 7110 software. Can you tell me how to get that software? I purchased the 7110 used without software.
  • 240 Answers
Begin by connecting your printer and installing any software according to the instructions that came with your printer. Next, open System Preferences and click the Print & Fax icon. Use the Print & Fax pane to configure your system to access the printer
try doing this and pls post ur comment and rate my solution
Posted on Jun 18, 2009
  • vijay A Jun 18, 2009
    If you sent a print job to your printer, but it’s not printing, check to see if the print job is
    stopped or on hold by clicking the printer icon in the Dock. (If no icon appears in the
    Dock, open Printer Setup Utility in the Applications/Utilities folder and double-click the
    printer’s name.) If the window for the printer says “Job Stopped,” click the Start Jobs
    button. If “Hold” appears beside the job name, resume printing by clicking the job
    name and clicking Resume. If a print job has stopped printing because of a technical
    error, you can delete the faulty job by selecting the job and clicking Delete. You can
    then try printing the job again.
    If your printer doesn’t seem to be working as expected, you may need to check the
    manufacturer’s website for updated print drivers. Often the latest printer software is
    available for downloading.
    h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=91472&lc=en&cc=us&dlc=en
    u can download the required software in this site by specifying the operating system used by you.
    if your problem is fixed pls rate this session thank u
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Printing off computer
Most likely your new cartridge has a damaged head. The tiny bit of electronics could have a fault, and therefore not be read properly by the printer. Try taking the cartridge out and cleaning the head with rubbing alcohol - both on the cartridge and the printer - then put it back in. If that doesn't work, try a different cartridge.
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
How to use ink I have purchased?
i don't know what printer do you have, but HP print cartridges are resetable, just find it on google, type your printer type and reset cartridge
Jul 10, 2009 | HP Office Equipment & Supplies
Reset HP 7110 to factory settings
usually setting your computer to a date before the expiration date of the cartridge. If your printer has a date function try this first on your printer.
Jun 27, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Problem receiving faxes with hp officejet 7110
Most likely it is a phone line problem, not ypur machine. Fax modems work or they don't work.
make sure your phone line is not digital.
Mar 16, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Hp printer 7110
hi,
Try to remove the black ink cartridge. From there, you can check the expiry date of the Ink cartridge. If its already expired, then you need to use another black ink cartridge that is not yet expired.
Thank you so much.
adonscott
Jun 18, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Hp officejet 7110
1st how old are the cartidges ink could be solidified.
2nd did you take the plastic off of the new ink heads?
try runninng clean pint heads from printer control
Jan 04, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Replacing ink cartridge
try with claening the nozzel and also claen the conacts of catridge by pencil eraser bye
Sep 28, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Hp Officejet 7110 Not Printing From Computer
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Hp officejet 7110 battery and cmos location
The battery is located behind the left front cover. Open the printer, grasp the left front cover from inside the printer and pull to open. Look inside the printer to left and you will see it.
It is enough to remove for a minute to reset the expiration.
But I'm afraid after that the printer may not keep the date and time when turn off.
Jun 19, 2007 | HP OfficeJet 7110 All-In-One Thermal...
HP OfficeJet 7110 All-In-One Thermal Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
